Old 07-25-2003, 12:42 AM
CB91StangGT CB91StangGT is offline
Send a message via AIM to CB91StangGT
Biggest tranny cooler available
I want the biggest cooler I can find for my AOD now that it has a 2800 converter in it. I currently have the B&M 19,000gvw cooler. Is this big enough?
1991 Mustang GT Conv: 60,000 original miles, 2nd owner :banana:
Built AOD w/2800rpm stall, 3.73's, aluminum d/s, 2 chamber Flowmasters, BBK shorties, 65mm tb, 73mm maf, subframe connectors.
1990 Mustang LX Conv 25th Anniv: 50,000 original miles, 2nd owner :banana:
2 chamber Flowmasters, o/r h-pipe, Pro 5.0 shifter.
Old 07-25-2003, 06:44 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Dude, I got the same one in my car. Been running it for 2 years now, no problems. You know my deal and such, so you knows its legit. Although you can't have too much cooling when unwanted heat is an issue. I just got your e-mail, I'll get in touch with you later about installing the new one.
later.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-25-2003, 11:42 AM
Yeah I thought the 19,000gvw was big enough, but HiTech (tranny shop) highly recommended getting a bigger one to go along with the new radiator I got. I was thinking of running both coolers at once, does anyone know if this is possible?
Old 07-26-2003, 12:05 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Both coolers as far as the one you bought and the one in your radiator? Yes you can, you can run as many coolers as you want. I also would use B&Ms remote tranny filter too.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-26-2003, 12:07 AM
GTStang's Avatar
Stang Guy
You can run as many coolers as you desire. I also would use B&Ms remote tranny filter also.
Old 07-26-2003, 12:12 AM
HiFlow5 0's Avatar
Stanger
Yes, good idea! It would help keep the tranny free of debris if the converter ever broke up.
-2013 Ford Flex
-1999 Ford F150
Old 07-26-2003, 04:05 PM
How much is a remote filter and where can I find one? I want to order it soon because I have to drop the valve body to install an "A" servo so it wouldn't hurt to add a new filter when I put it all back together!
Old 07-27-2003, 12:26 AM
HiFlow5 0's Avatar
Stanger
You can pick up a Perma-Cool kit from Summit for about $80. It also includes a temp gauge to moniter trans temp. Or you can get the Summit kit for $30, minus the gauge.
-2013 Ford Flex
-1999 Ford F150
Old 07-28-2003, 12:07 AM
Do you have a temp gauge?
Old 07-28-2003, 02:46 AM
GTStang's Avatar
Stang Guy
When I had a built AOD I was had a trans temp guage. Definetly worth the small investment to keep an eye on things.
Biggest transmission cooler the 95-98 will allow searcherrr Windstar 6 12-18-2007 03:44 AM
flow direction of tranny coolant lines & add a tranny cooler stevenf12801 Caravan | Voyager 1 09-12-2007 08:43 PM
Installing tranny cooler, tranny temp gauge Moser97 Blazer 31 05-04-2006 01:55 PM
Perma Cool Tranny Filter and Tranny Cooler sanford7575 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 07-12-2004 01:50 PM
Tranny cooler un4gvnbb Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 06-18-2003 06:03 AM
