| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Deep thoughts on amplifiers
I was wondering, is an amp that is 2 ohm stereo stable going to be able to push a 2 ohm mono load?
I have a amp bridged and running at 2ohms on two SVC 4ohm subwoofers. would wiring it positive to positive negative to negative like normal each subwoofer to it's own channel give me a 2 ohm or a four ohm load? |
ok ohmage....
your amp at 2 channels X wattage can push 1/2 that on a 4ohm speeker. bridging will give you a single four ohm load with two speekers you are again halfing your maximum output beacouse you are going up to 8ohms. as far as wiring goes your looking at going posative to the pos on your first speeker. then the neg out to the pos on 2nd sub and neg to the neg on 2nd sub does that make sence. what your doing is just bridging the middle. the neg of sub 1 wires to the pos of sub 2. |
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
well his speekers are 4 ohm impedance so no matter what hes looking at 4 ohms thats if he has only one sub. as soon ad the 2nd amp is connected the load becomes 8ohms as an ohm is a measure of resistance.
Re: Deep thoughts on amplifiers
