Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 02-19-2006, 05:25 PM
kyleholt11 kyleholt11 is offline
2.3L 1994 ford tempo engine problems!
My car has a problem and i cant figure it out. heres what happened. my brother drove my car and i think he over-reved the engine and now none of the pullys are turning! but, when i took off the belt the crankshaft pully turned. whats the problem, do any of you have any ideas of what is wrong with it?
Old 02-19-2006, 07:18 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: 2.3L 1994 ford tempo engine problems!
one iof the pulleys is locked up (id say waterpump)..
tempos have a rev limiter (should, anyways) so it would just bounce off the limiter instead of "over-revving"
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 02-19-2006, 08:45 PM
So how can i fix it?
Old 02-19-2006, 10:13 PM
pre98zetec's Avatar
replace the locked pulley, if its the water pump replace the water pump.
-Josh-
Old 02-19-2006, 10:42 PM
Thanks for the advice! i got another question what do i do to make my car have greater top speed and greater acceleration?
Old 02-19-2006, 10:48 PM
pre98zetec's Avatar
check out www.tempotopaz.com , I don't drive/pay attention much to my tempo anymore (More interested in my Contour)
-Josh-
Old 02-20-2006, 09:41 AM
Is there any performance Mods?
Old 02-20-2006, 09:44 AM
Oh i almost forgot, how do i fix a locked up waterpump?
Old 02-20-2006, 10:41 AM
pre98zetec's Avatar
replace the whole water pump assembly. First you should find the pulley that's lock. The waterpump was just a suggestion from me. It could be something else.
-Josh-
Old 02-20-2006, 11:22 AM
Ok, here is the problem. when i take off the belt the crankshaft pully turns when i turn the car on , but when i put the belt back on, the crankshaft pully does not turn while the car is on. also while the belt is on, and the car is on, I can move the belt with my hand! Could it be the crankshaft pully that is messed up?
Old 02-20-2006, 11:33 AM
pre98zetec's Avatar
sounds like that could be your problem.
-Josh-
Old 02-20-2006, 11:43 AM
Thanks for the information! Im having a friend come over and look at it in about 20 minutes! maybe it will be fixed then!
Old 02-21-2006, 09:30 PM
What can i do to my car to make it go faster and to sound better?
Old 02-22-2006, 01:25 AM
pre98zetec's Avatar
there isn't much for the 2.3L unless you want to spend alot of money.
-Josh-
Old 03-03-2006, 06:05 PM
thenks for the info! um, how do i install a tachometer in my tempo?
