Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 07-24-2003, 06:04 PM
beigecar beigecar is offline
Unhappy Ford Tempo Problem
My 92 Ford Tempo alwasy shakes to die when it runs while the brake is pressed, i.e. while you backward parking, after pressing the brake for 20 second, it starts shaking and seems to die. But if i stop, and give it some gas, it becomes ok again. Does anyone have any idea for this problem, thank you in advance.
Old 07-28-2003, 10:17 AM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
First, do your brake lights work? Ford has a "BOO" switch that won't signal the EEC unless the lights are good. The bulbs are acually the ground path for the circuit. "BOO" stands for Brake On/Off. Can't remember if you're car has this or not.
Try visiting us at www.tempotopaz.com
The site will be back up early this week. It is down for maintenance right now.
The absolute, very first thing to do when troubleshooting these cars is to read any codes stored in the EEC-IV.
Check to make sure your SES light will come on. When you first turn the key, all the dash lights illuminate - and the SES light should work as well. If this is ok, all you'll need is a short jumper wire, and you'll be reading codes. More on this later.
Keep us posted.
possible ford transmission problem synthetic003 Expedition 2 09-22-2010 10:33 AM
87 ford truck Problems With Starter Grinding When Truck Is Running seatacwhat F Series 2 07-25-2010 12:05 AM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
91 ford tempo problem zedkoman General Discussion 6 03-13-2005 02:37 AM
Ford Tempo Problems athome890 Engineering/ Technical 3 01-07-2004 01:21 AM
