Old 07-24-2003, 01:24 PM
red_civic_dx's Avatar
red_civic_dx red_civic_dx is offline
ZC head parts need help please!!!!
ZC head parts? (this post)
do 88-89 integra cylinder head parts fit a zc i.e valve springs/stems/ seats etc... i want to know cause my ZC was blowing blue smoke when it idled and it used up quite a bit of oil. Now im not ruling out the PCV valve or the piston rings but if it were the head could you use 88-89 integra parts?>
Old 07-24-2003, 02:23 PM
SmokinJs420's Avatar
SmokinJs420 SmokinJs420 is offline
Send a message via AIM to SmokinJs420
If I did my research right, then the Dohc ZC uses a6 top and teg bottom, I know you can get everything for that engine *except* valvetrain. You can have your valvetrain professionaly bored/fitted to an LS engine, but that will cost hella $$$. You can then buy performance valvetrain. Here is a badass ZC site that gives a lot of useful info.
http://geocities.com/chipman_13/zc.html
Old 07-25-2003, 12:16 AM
you got the bottom and top end parts wrong
I do know that the bottom end is from an A6 and the top is from an 88-89 teg,.......
Old 07-25-2003, 01:21 AM
My bad
Old 07-25-2003, 02:01 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
The Teg Head A6 bottom end only really has to do with the parts in them, they are by no means the exact same thing. Then again the cams, cam gears, and valve cover on a Teg aren't the same as a ZC and I'm sure a lot of the other parts aren't.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-25-2003, 03:10 AM
91civicDXdude's Avatar
i too have heard that the LS valvetrain can be fitted into the ZC, but i've compared my LS side to side with a ZC and the LS is a couple inches wider.. i dont see how it would fit.
Old 07-25-2003, 01:11 PM
what about the parts inside the head
like the valve springs and vlave seats and stems all that junk within the head ..what car can i get them from?
Old 07-25-2003, 09:18 PM
You can't. You'll have to check ebay for a new head or talk to someone in Japan.
91 cav Huge prob need help PLEASE!!!any help would be amazing 91cav666 Cavalier Problem Diagnosis 2 05-27-2005 09:13 AM
DL and head lights problem!! Help! Please Read!! dupadupa Grand AM 1 02-08-2005 08:13 PM
need some parts cheep help please fredthedragon '88 - '91 Civic | CRX | Wagon | Shuttlee 3 09-27-2003 06:33 PM
part needed need help please!!!!! sirimport Sentra | 200SX (USDM FWD) 1 04-10-2003 07:50 PM
