Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 07-24-2003, 11:40 AM
SCRAP SCRAP is offline
Question Engine Swap ????'s
MY FRIEND HAS A 1987 CRX SI & HE WANTS TO PUT A D16A1 MOTOR
IN IT FROM A 1989 INTEGRA.
1. WILL THE ENGINE BOLT-UP WITH NO MODS?
2. WILL THE COMPUTER WORK WITH HIS FACTORY WIRING?
THANKS AHEAD OF TIME
SCRAP
Old 08-18-2003, 03:50 PM
cody_vg cody_vg is offline
Banned
engine swap
I know about the 86-87 but i heard that the 89 should be the same.
the parts you have to change is the hubs,axles,shift linkage,clutch cable, throttle cable,emissions box,upper and lower radiator hoses, the stock integra exhaust manifold with the civic down pipe. and the ecu although theres a long list of changes the motor pretty much bolts right up. reply back and ill discuss more.
Old 01-18-2004, 10:24 AM
rascaca rascaca is offline
Could you be more specific?
Do the 87 integra axles fit on the crx 87 si hub?
What do you mean about the throttle cable, is it too short?
Emmissions boxes??? Do you mean the EDL module?
i have A JDM ZC (88) black top from integra with cut harness. Can my Zc harness
be connected(with a connector) to the 87 si model or is it just splicing some connectors from the zc to the 87 harness(like the dist. change).
Thanks,
If you any links where i could get wiring diagrams of both my 87 crx si and the 88-89 integra d16/ZC it would be great also.
Thanks
Chris
Old 01-18-2004, 03:16 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: Engine Swap ????'s
how many times do i have to post this link, i should just put in my sig.
http://www.muller.net/sonny/crx/
its not the holy grale of swaps but it is the best bang for your buck with this era of honda
btw, there is no problem with pulling up and older thread but if you will notice the origional poster has not been active since 07-24-2003 so it is kinda useless
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 01-23-2004, 11:01 PM
87civicswapking 87civicswapking is offline
the swap can be done use the spindles and rotors from the integra and the axles including the center axle. the shift linkgage is a little long but will work without changing must use si ecu but d16 ecu gives you better performance motor mounts will all work from the d16 you might have to trim your hood support the dohc rubs the inside of the hood other that that it is a straight swap i have done four of them give me a post with more questions.
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
Engine Swap ???'s Gaurdian Grand Prix 0 11-10-2004 12:52 AM
engine swap ?'s sk8terCraig 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 6 10-23-2002 02:28 AM
