Old 07-23-2003, 07:10 PM
hondatool hondatool is offline
oil burning question
what are some reasons that i would be burning oil?
Old 07-24-2003, 01:10 AM
97civichx's Avatar
97civichx 97civichx is offline
Send a message via ICQ to 97civichx Send a message via AIM to 97civichx
well you could have a bad gasket somewhere so oil would leak into the cylinder or one or more of the piston rings could be bad so oil ends up in the cylinder and burns. thats the only things i could think of though, but i dont know too much.
97 civic hx
mod list: CAI, 17" wheels but now removed and much more to come.
not much of a list yet really
Old 07-24-2003, 08:17 AM
CivicEXRider's Avatar
CivicEXRider CivicEXRider is offline
How many miles do you have on the car? Any engine work done to it?
1. Worn rings
2. Blown head gasket
3. Valve stem seals are cracked/worn out. This usually clears up after the car heats up a bit. Really see smoking on startup.
4. Also, if the egr/pcv valves are clogged/stuck could cause very light smoke caused by not clearing the top end of oil gases.
Compress test is what I would recommend doing first.
Old 07-26-2003, 03:19 AM
how much does a compression test?...and what numbers should i look for?
Old 07-26-2003, 01:48 PM
wheel1856's Avatar
wheel1856 wheel1856 is offline
Send a message via AIM to wheel1856
about $12-$13 for the haynes manual. and another $5 for the pressure guage at the autoparts store. plus the total opportunity cost of the 25 minutes it'll take to do it in your driveway. Not sure what numbers you want (off hand) but the manual will tell you. should also have suggestions as to what the problem may be based on the pressure readings.
yeah a compression test is a good suggestion, and it's easy to do, you can do it in your driveway. just get someone to turn the key for you, unless you have freakishly long arms.
"Why yes, this is a GS-R."
Burning oil at idle bhw33191 Caprice 20 09-13-2009 01:43 PM
smoking from the oil filler cap, dipstick and exhaust jimgbgt MGB 2 07-24-2009 04:26 AM
Proactive Oil Burning Prevention:Head Gasket Oil Drain Issue metalbeast Metro 6 08-02-2008 10:51 AM
Oil burning smell, but oil still golden color & good level just before oil change Shpyder Off-Topic 4 07-25-2004 12:53 PM
oil burned too fast? AznVirus Maintenance 6 08-17-2001 03:37 PM
