Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-22-2003, 09:35 PM
smbenson58 smbenson58 is offline
99 Camry Intermittant Stalling
My 99 Camry LE runs fine most of the time but every few days it seems to have a problem with low RPMs and stalls when in gear. If I wait about 15 minutes and restart it, it runs fine. It seems like it is not getting enough gas or the right mixture. Could it be a sensor? Vacuum sensor or fuel pump sensor? Has anyone else had a problem like this? The car has 83.5K miles and is a 4 cylinder. Thanks...
Old 10-08-2003, 08:58 AM
cjsherm02 cjsherm02 is offline
Camry Stalling
I have a similiar problem with my camry also, except it starts right up after stalling. I have 80,000 miles on my 4 cyl. It seems to usually occur on hot days when stopping. Runs fine on cooler days. Running with AC on or keeping RPMs up seem to help. Have you been able to solve your problem?
Old 10-08-2003, 04:37 PM
No, I was not able to solve the problem. I had it in the shop several times. I needed a car that is dependable so I traded it in on a 2003 Camry.
Old 11-18-2003, 06:28 PM
rydepowder rydepowder is offline
same thing
i'm having the same problem. the only differnce is, in my situation, the frequency of the problem increases after rain and in high humidity. keeping the rpm's up helps but hasn't fixed the problem. have either of you figured out what is causing this problem
rydepowder
Old 12-03-2003, 09:39 AM
ChewToy's Avatar
ChewToy ChewToy is offline
Send a message via AIM to ChewToy
Re: 99 Camry Intermittant Stalling
Check for a bad distributor. You may also want to do a quick tuneup.. new spark plugs, cap, fuel filter,... pretty sure the distributor fixed my stalling problem and then I had a starting problem and new plugs and new fuel filter resolved that problem as well! 160k mi's and still taking a licking.
Old 12-03-2003, 12:12 PM
Thumbs up air recirculator
well, i've solved my problem for the time being. my cousin is a mechanical engineer and took a look at my car. he found that the, for a lack of technical jargon, engine exhaust recirculator (on top of the engine with efi written in red on it) was incredibly dirty. we simply removed a hose and sprayed some cleaner in it, used a brush to scrub out the gunk and started it up to push the rest of the debris out. it hasn't had any problems since even after rain and humidity which seemed to be a major variable in the problem. oh ya, and its really cheap to do so try it before droping some coin.
'95 Lincoln intermittent stalling issue TexasBee Town Car 4 10-14-2010 06:59 PM
'96 Camry 4-cyl 2.2L Idle Control Sensor Maulana Camry/Camry Hybrid/Vista 4 03-18-2010 11:29 AM
95 Camry Intermittent Stall caddyman379 Camry/Camry Hybrid/Vista 4 07-30-2008 01:39 PM
95 Camry intermittent start/stall problem wadehi48 Camry/Camry Hybrid/Vista 18 05-20-2008 04:50 PM
1999 Toyota Camry intermittent stall kirubel98 Camry/Camry Hybrid/Vista 3 08-21-2005 12:02 PM
