Old 07-22-2003, 07:48 PM
Crimson's Avatar
Crimson Crimson is offline
Send a message via AIM to Crimson
Long time to crank?
I have a 89' cherokee sport and it takes fucking forever to crank. I have to give it a lot of gas, and try it a bunch of times.
Old 07-22-2003, 08:44 PM
spooleffect's Avatar
spooleffect spooleffect is offline
Send a message via AIM to spooleffect
Sounds like a ignition prob. It could be that the timing is not accurate or that the coil is starting to go. If not that then maybe the fuel pump is gonna die.
It could be a few other thing but thats what I think it could be.
Old 07-23-2003, 02:16 AM
Crimson's Avatar
Ive had it a year and its been doing it the whole time, the people I bought it from said its been doing it for god knows how long and its just something you get used to...I still havent lol
Old 07-23-2003, 02:37 AM
Check your ignition system and your fuel pump.
Old 11-14-2003, 09:22 AM
jclute jclute is offline
I also have a 89' cherokee and it does take a long time to turn over. I read somewhere that some of the vehicles produced have this delay because of the ECU. I know how frustrating it is but mine has always started like that.
Old 11-14-2003, 02:34 PM
ultraspaceman ultraspaceman is offline
Sounds like the CPS (Crankshaft Position Sensor) is going bad.
This is very common with earlier model Cherokees.
Old 11-16-2003, 10:03 PM
fdrepairshop fdrepairshop is offline
Send a message via AIM to fdrepairshop
Re: Long time to crank?
change the crank sensor like spaceman said, almost always bad .
Old 02-03-2004, 12:03 PM
94jeepGRCH 94jeepGRCH is offline
What would you say about a 94 Grand Cherokee with the same type sypmtoms. Sometimes it has long crank times and you need to push on the gas and other times it starts right up. All ignition components have been replaced. I think the only sensor that hasn't been replaced is the Cranshaft position sensor. Also plugs seem to be running real hot. Engine was recently rebuilt due to a hole in the #6 piston. Never figured out the cause. Thanks for the help in advance.
Old 06-02-2004, 03:33 PM
Saudade's Avatar
Saudade Saudade is offline
My '88 Laredo would die when hot, then restart once it cooled off. Based on the comments here and elsewhere, I changed the CPS and all is well!
Old 06-02-2004, 11:13 PM
avmx avmx is offline
I own a 97 sport, the long cranking only occurs when the truck has been sitting for a while (overnight). What I have found is, turn the ignition to just before starting, wait 10 sec. then crank to start. The truck starts with less cranking. You have to wait for the fuel pump to pressurize the fuel system
92 ex timing belt not lining up at TDC (cam pulley/crank pulley) Swansen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-01-2009 12:02 PM
Long time members have been wanting this for a long time Darkwing '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 01-08-2005 06:42 PM
Have to crank engine for a long time to start skit0321 Aurora 1 06-20-2004 06:27 PM
Been around a long, long time. Newbie. darsdoug Introductions 0 02-08-2004 04:52 PM
long time lurker, first time poster swollen Car Modeling 15 03-25-2003 03:32 AM
