Old 07-22-2003, 02:30 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
MSD ignition help, please...
Anyone installed an MSD ignition before?
I'm ready to hook mine up, and I'm trying to figure out the wiring for it. I'm using an MSD 6A, with an MSD modified distributor cap, and a MSD Blaster II coil.
My main question is do I have a Magnetic Pickup ignition, or a Points style ignition? There's two different ways to wire it depending on which I have, and I have no idea... I'd bet that it's Magnetic, but I have no idea.
Also, does my car have a ballast resistor? I think only if I have a Points style ignition right?
Do I have to wire my tach to the tach output of the MSD, or is that not necessary?
Hope someone can help.
Old 07-22-2003, 02:32 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
jeef's got one...where's he at?
SOLD!
Old 07-22-2003, 02:35 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
points is pretty old school stuff (as im my 73 MG had one stock) ... so im willing to bet you have a Magnectic pickup ignition.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 07-22-2003, 03:26 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
dammit, i had a huge awesome walk thru all typed up, and it gave me an error when posting
ill settle for just giving you the link to a diagram
here
just noticed you have a blaster coil as well. take the orange and black, and instead of hooking them to the stock coil, take the stock coil out and wire the orange and black wires to the blaster.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 07-22-2003, 03:35 PM
ci5ic's Avatar
Perfect. That I can understand.
I had that diagram, and I was pretty sure that's what I needed to do, so thanks for clarifying.
One question though, should I just tap the other two wires outside the distributor, or should I run the wiring into the dizzy to connect to them?
Oh, and also, what about the tach? Do I need to re-wire it to the MSD box, or will it still run off the dizzy?
Old 07-22-2003, 03:42 PM
EF You's Avatar
EF Life Giver
you shouldnt have to wire the tach up. it will work fine. and yes, you have to run the wires into the dizzy, well at least the two that hook up to the existing wires. because the wires hook up to other stuff in the dizzy, and are a different color than the ones on the plug that comes outside the dizzy.
Old 07-22-2003, 08:01 PM
ci5ic's Avatar
Done.
Thanks for all the help.
Pics:
http://www.automotiveforums.com/vbulletin/t121143.html
MPG of 93 Dakota 5.2 Magnum w/MSD Ignition tripod12133 Dakota 0 07-27-2010 10:21 PM
1973 el camino- electronic ignition. HELP Landmeier El Camino 3 04-14-2009 08:33 PM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
1997 s-10 blazer keys stuck in ignition help please buckeyboy Blazer 1 05-06-2005 12:33 PM
Msd Ignition Help sarsourus Sentra | 200SX (USDM FWD) 0 05-06-2004 12:36 AM
