Old 07-22-2003, 11:41 AM
taurus4433 taurus4433 is offline
Question 2002 Taurus programming key fob
I want to prchase a key fob from e-bay but I don't know how to program it! If anyone can give me directions it would be greatly appreciated.
Old 10-06-2003, 11:44 AM
Kirkwwhite Kirkwwhite is offline
Re: 2002 Taurus programming key fob
Turn ignition key from off to on 10 to 12 times quickly (Try 10, then 11 then 12, till it works). Door locks shoudl automatically open and close, which indicates you are in programminmg mode. Click arm on the key fob and it shoudl be programmed. Repeat for other key fobs. I read this in internet and just had Ford dealer try the same method while helping me with Windstar Key fob program issue.
Old 10-07-2003, 12:44 PM
Pokey Jr Pokey Jr is offline
Cycle the key in the ignition from lock to run 8 times within 10 seconds ending in the run position. The locks should lock and unlock.
Now press any button on one transmitter and it should lock and unlock again. Do the same for the second transmitter and it should lock and unlock, then switch the ignition off and it should lock and unlock once more. Verify that the keyless entry transmitters work properly.
You must have at least two transmitters to program. (even if one works)
Up to 8 keyless transmitters can be programmed to one vehicle.
need to know how to program key fob missmygsxr SC/SL/SW 4 10-27-2011 01:32 AM
'09 altima program key fob jib922 Altima 0 08-26-2010 09:18 AM
Need Help Programming 2003 Taurus Remote Key Fob tnkoozman Taurus | Taurus Wagon 2 07-10-2006 06:05 AM
Programming Key Fob for 2002 Grand Caravan jkyoutsey Caravan | Voyager 1 11-09-2005 03:51 PM
Programming key FOB for '98 GMC Sierra K1500 opie32 Sierra 0 10-04-2002 12:36 PM
