Old 07-22-2003, 09:31 AM
snipez's Avatar
snipez snipez is offline
Lack Of Power, Engine Races, HELP!
1993 grand am SE
134,000 km
auto
3.3 V6
recent tranny flush
The problem is:
Engine is very loud until it gets into 2nd gear.
Engine has no power.
Once it gets into 2nd gear it runs fine.
It should be switching gears under 3 RPMS not 4 RPMs ( in other words it takes forever for it to switch)
I stomped the gas pedal hard, this is where problem started
could it be the TPS or vaccum?????
thanks
Old 07-22-2003, 07:05 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
I think you are looking at a trans problem. You are getting a slip in 1st gear. Considering you just had the trans flush done I would bet on a trans problem.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 07-23-2003, 10:21 AM
snipez's Avatar
no, the trans seems to be fine, it shifts perfectly.
Old 07-23-2003, 12:42 PM
pcv pcv is offline
Check the tranny oil. Make sure it is full. If you have no power and the tranny shifts at a higher rpm, its a tranny issue. Take it back to wherever you got the tranny service done and get them to look at it. All the best.
NOTHING LIKE AN OLD CAR.
Old 07-23-2003, 12:53 PM
snipez's Avatar
the funny thing is, before I got a tranny flush i added a very small amount of tranny fluid and the problem went away. I'm tempted to add some more but what all the results of too much fluid??
Old 07-23-2003, 01:04 PM
pcv pcv is offline
Start the car, leave it running in park and check the tranny dip stick. Clean it first and reinsert it and pull it out. With it pointing down, read the level. Is it below the crosscheck? If it is below, add a little fluid at a time and recheck. It should be a little below the the top of the crosscheck.
Old 07-23-2003, 07:03 PM
snipez's Avatar
but wouldn't it be safe to say the level is correct after a flush, or did the morons not put enough fluid in
Old 07-23-2003, 09:17 PM
jon@af's Avatar
jon@af jon@af is offline
The Media Guy
Send a message via AIM to jon@af
Make sure your tranny throttle valve cable is adjusted correctly, because if it's not it can cause late shift, early shift and other problems, also check to make sure it's not binding either.
AF User Guidelines <----Click and read if you don't know these.
"Dream as if you'll live forever. Live as if you'll die today."
A Blog By Swigz
Cotidie damnatur qui semper timet; Aquila non captat muscas.
Old 07-23-2003, 09:34 PM
Flatrater's Avatar
Main GM Guy
Never assume!! Too much can have the same effect as not enough!!
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 10-17-2003, 06:55 PM
Trixcomp Trixcomp is offline
yeah check the fuilds. it never hurts to check. heck, the second you notice off shifting, or under power. check shit out. (unless u are heading into a head wind :-) ) another point. if u are only missing power in one gear, it is the tranny, I am no expert at transmissions, but I would think too much tran fluid would lead not optimal running and shifting. if u are a little over, I don't think there is a huge problem but u would want to correct it
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
1992 MPV lacks power. Really need help Please! ffullflash MPV 4 11-28-2005 09:07 PM
92 Toyota Truck V-6 engine lacks power, 3.0L, help! froquejr Pick-Up 4 06-08-2005 12:53 PM
Engine Lacks Power N E suggestions?? DTalon Off-Topic 6 07-21-2004 11:45 PM
Low end lack of power engine hesitation mikey58 Pick-Up 1 04-19-2004 12:34 PM
