Old 07-22-2003, 03:30 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
securing a sub box.
ok in my accord in the trunk my bazooka box fits perfectly between the floor and the top support bar in the trunk, almost so snuggly, that I have been driving around with it, and have had it slide out every once in a while, but now I am finally ready to secore that bad boy to the floor, but all that the floor is, it cheap cardboard covered in carpet. would it be a good idea to buy a sheet of 1/4-1/2 inch plywood, and tack that to the cardboard, ( I have no problem shaping it to the size and shape of the cardboard cutout) or would it be better to just do the whole thing with the plywood, and carpet the plywood? which would look cleaner? I also do plan to add dynamat, or some variation of it soon. and if I should carpet the plywood where do I get the carpet from to match the rest?
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 07-22-2003, 01:47 PM
whiteracer whiteracer is offline
Send a message via AIM to whiteracer Send a message via Yahoo to whiteracer
no, plywood is too heavy. It would be stupid. Go to your local hardware store (home depot) and buy some L shaped brackets. Something small and discrete. The smallest i could find were about an inch wide and about and inch long. They should have a couple holes in each leg of the L. those are for screws. The L brackets should say what kind of screws will fit the width of the hole. They are used for putting two pieces of wood perpendicular. These two pieces of wood substituted by the sub box wall and the floor of the trunk. And put them in the back so no one can see them.
Jeez, the advise i give is on stuff i have yet to get around to doing.
Name's David.
Old 07-23-2003, 04:29 AM
hmm, more drilling, why I asked about the plywood is that my board is getting kinda concave, from the weight of the sub box, and that's what I did for my tracer that I had before when water got into the trunk, and bent the spare cover all up. I don't really care about weight, I don't race this car, it's just for my fun (thump thump).
I read you're having a problem with your car as well, mounting R-1's in the front. send a pic of the brackets/seats, and your stock seat mount brackets, and I'll get back to you with a solution, I'm very good at this sort of thing.
Old 07-24-2003, 12:11 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
I have 1/4" plywood in my hatch and it's really not that heavy. The only problem with drilling into whatever you plan on doing is if you needed the jack or spare tire some day.
Old 07-24-2003, 05:53 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
For what your purpose is, and added weight not being a factor, plywood or MDF (mutli-density-fiberboard) would be fine. Sub boxes are usually out of MDF. I know of the concaved trunk covers you are taking about. Putting down MDF and wrapping it in carpet looked fine when I saw it done. If you wrap it in vinyl, you could do designs or words on it. Lay down body filler or similar on the MDF in the shape or letters you want, let it dry hard, and wrap the vinyl tight over it. The letters/design will be raised up. If done right, it can look kind of neat. Just an idea for you. Good Luck with it.
Old 07-24-2003, 02:05 PM
yeah, that would be cool, but for now I think I'll just tack some carpet onto 3/8 inch plywood for now.
Old 07-24-2003, 02:31 PM
Ricochet's Avatar
Banned
That's what I did with my hatch to mount the bottle. Now that I don't have n2o I need to figure out something else to do with that space. I'll probably end up just putting the seats back in for practicality, or tearing everything out for weightloss... haven't decided yet.
A Questin about subs and sub boxes!?!? benji-man Car Audio 1 01-21-2007 05:24 PM
For Sale: Dual 12" sub box for Kicker L5/L7 subs Gateway 3000GT/Stealth 0 06-02-2005 09:24 AM
Dual Sub Box...which way to face subs? EmpireKing01 Car Audio 12 05-02-2004 09:03 PM
Offering my services: Custom Designed Sub boxes P11GT Audio/Security 21 01-11-2002 07:32 PM
Offering my services: Custom Designed Sub boxes P11GT General 3 10-31-2001 07:45 AM
