Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 11-21-2001, 11:03 AM
lloyd_nickens's Avatar
lloyd_nickens lloyd_nickens is offline
Angry Antenna Problems
When I listen to my CD's I can still hear the radio in the background if the CD is playing a quiet passage. Why is this? Everything is grounded like it is supposed to be. Is the antenna wire and corresponding adapter really sensitive? I am using a Panasonic 800U with a wiring harness and antenna adapter.
"God Bless BASS, What Would We Do Without It?"
"If You Can Breathe, Turn The Music Up."
Old 12-04-2001, 04:20 PM
steven scott steven scott is offline
Lightbulb Audio help
Sounds to me as though the unit in question just happens to be VERY susceptible to RF interference, or it could be a fault with the unit itself. Try first disconnecting the aerial and seeing if it still occurs. Secondly, try (temporarily) wrapping the unit in tin foil then seeing if the phenomenon is still present - if not (or its less noticeable) then you got RF interference. If so, then it sounds to me like a fault somewhere in the source switching section of the preamp. Try this out to at least narrow down the problem. Incidentallyy it is not that unusual in ANY piece of Hi Fi be it domestic or in car to occasionally suffer from this. I once had a domestic amp that would pick up radio through the phono input in certain atmospheric conditions. Tres strange. Good Luck and keep me posted.
Old 12-07-2001, 06:27 AM
Its the radio. It's wicked sensitive. I guess nows the time to get Pana's 7 inch dvd player
99 Jetta antenna problem tsargent62 '97 - '03 3 12-29-2005 12:34 PM
sunroof and antenna problem choiboy Off-Topic 2 01-10-2004 12:33 PM
antenna problem elude92si Prelude 2 01-07-2004 05:55 PM
antenna problems B13 ROB P10 General 3 03-15-2002 01:43 AM
Power Antenna problems seanzi Maintenance 10 09-21-2001 02:00 PM
