Old 01-09-2004, 06:22 PM
choiboy choiboy is offline
sunroof and antenna problem
my sunroof isn't working its won't open or close - i located the runroof fuse and change it with a spare ones and with new ones. its didn't work. i try to push it up with my hand its won't open. anyone have any ideas to fix it?. btw i opened the sunroof today - but no wires or electronics stuff around it..
And i just got this car so the radio was locked so i never got a chance to hear the radio on stock radio.so i didn't see the anntena working or not - so i got new cd player installed but the anntenna isn't working or they didn't connect the anntena power to the cd player?. who know is there a way i can test it maybe unscrew the antenna?. i haven't mess around with it yet. anyone have any ideas? these little problem i have is keep buggin me. thanks btw its a 96 gs
Old 01-09-2004, 06:51 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
Re: sunroof and antenna problem
If the antenna is hooked up to your cd player it should raise when you turn the radio on. It won't go up on the cd function. It could either be that the power antenna line isn't hooked up or the little motor that raises it is fried. You can get a new one from a dealership or ebay, should that be the problem. The only thing, non electronic, that I know about the sunroof is the sliding cover that blocks the sunroof if opened the slightest... but that usually stops it from closing.. not opening. So I really don't know. I'm sure someone on here might though.... good luck
V8's are like tampons, every pussy needs one!
Old 01-10-2004, 01:33 PM
i was messing around with the sun roof today - and i noticed the wires wasn't connected - so i connect them together wala. thanks
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 02:22 PM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 09:49 AM
Antenna and Radio problems hkmorgan87 LeSabre 3 12-08-2006 07:49 PM
sunroof and supercharger problems on 99 GTP gln_mllr Grand Prix 8 05-22-2006 06:31 PM
Power Antenna problems seanzi Maintenance 10 09-21-2001 03:00 PM
