Old 07-20-2003, 04:36 PM
projectsilvia97's Avatar
projectsilvia97 projectsilvia97 is offline
Send a message via AIM to projectsilvia97
Question what head to put on b20?
I'm not sure what head to put on the b20. Should i put a B16 head on or a B18c5 head. Also, i'm wondering what kind of compression ratio i should have if I want to go turbo. There's this place up in Michigan that does a whole B-series rebuild. I'm not sure what kind of pistons I should put in and what the compression should be on them.
Thanks.
Old 07-20-2003, 04:42 PM
97gsr's Avatar
97gsr 97gsr is offline
Send a message via AIM to 97gsr
pick whichever you want....they are both comparable, and both good choices...
probably go with the b18c5 since you want turbo, then you have some what of a port and polish done....
as far as compression for turbo.... 9:1 seems to be the norm...
i wouldn't wonder much higher than 10:1!
ITR inside
Old 07-22-2003, 12:27 PM
4g4d_getone's Avatar
4g4d_getone 4g4d_getone is offline
yeah if u wanna go turbo then do the b18c5 but if u wanna go all motor then do the b16
Y LOOK FAST WHEN YOUR NOT?????????
Old 07-22-2003, 01:21 PM
chechin chechin is offline
Send a message via Yahoo to chechin
I think if you wanna go turbo all that matters is that you use low CR pistons, between those 2 options in heads I think it doesn't matter, both look the same considering your application.
what head can i put on my soch ZC ???? 91hondaHB '88 - '91 Civic | CRX | Wagon | Shuttlee 4 11-24-2006 10:57 AM
b16 head on b20??? or k20a4 kribban Let's get Technical! 1 10-21-2004 01:40 PM
best head for b20 djnutinurface Engineering/ Technical 9 07-28-2003 10:57 PM
1st gen B16a head on B20 crvtec pontiacgagt Engineering/ Technical 5 08-19-2002 10:31 AM
b16a head on b20 block query jOYRiDe Engineering/ Technical 2 05-06-2002 06:13 PM
