Old 06-27-2002, 10:32 AM
pontiacgagt pontiacgagt is offline
1st gen B16a head on B20 crvtec
Are there any problems with using the head from a first gen b16a when building a crvtec engine. Most B series engine parts are interchangable?
Old 06-27-2002, 11:02 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
You need to get the compustion chamber on the head machined out to match the larger bore of the B20.
Thats the only real problem I can think off.
The problem being if you get it wrong the engine will never work properly.
Old 07-02-2002, 12:08 AM
1990 CRVTEC Integ 1990 CRVTEC Integ is offline
Send a message via AIM to 1990 CRVTEC Integ
i have a b16a1 head on my b20 and it runs fine.
Old 07-02-2002, 01:54 AM
Moppie's Avatar
Master Connector
Well if you didnt get the head machined before you stuck it on, then it could be running a lot better.
Old 07-05-2002, 12:03 AM
the head and the block need to be machined for the swap to work. so yes mine is machined
Old 08-19-2002, 09:31 AM
Jeffbunge Jeffbunge is offline
Send a message via AIM to Jeffbunge
The serious problems I know you could have would be if you advance your intake cam timing too much (past +3° or so) the valves can hit the piston, that causes large problems. Reference www.crvtec.com
I have a slow integra now, but don't laugh, cuz one day you'll pull up next to me, you'll look up, and i'll be gone.
Will hit 10's
CRVTEC+Large turbo = Wow
www.crvtec.com - great site
