Old 07-19-2003, 12:27 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
thrown rod bearing question
ok next step on my car repair...
got the pistons out and found the source of my problem. the bearing in cyl 1 (i think thats the one on the far driver's side) was completely shot and the rod was bent too. i have parts for those but here comes my next problem maybe.
the surface of the crank where the bearing meets it looks all scratched up and all. now can i clean that up somehow and in doing so will i need a different size bearing? or do i have to replace teh crank (which wouldn't be too bad b/c i have another one from my spare block but taking the block out of the car would suck...)... so any help would be great. thanks
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 07-19-2003, 03:33 PM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
You need to take the crank to a machinist and have them machine the crank for you. Also get them to provide the proper size bearings for the newly sized crank.
Beer tastes better upside down.
Old 07-19-2003, 10:16 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
man i'll tell ya right now once you start getting into all that crap its gonna be cheaper/easier to swap... i was just faced with the same delima... i spun a rod bearing, and buy the time the bearing were changed, the crank was milled (100 bucks) new over bored pistons, rings, and a bore and hone (if you don't do this the pistons won't seat properly) then all the gaskets... man its just not worth it, unless you can afford aftermarket stuff...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 07-19-2003, 10:30 PM
Jay eS Iye's Avatar
ok i was kinda unclear, i have a spare block in my garage that has everything in it. so i have a spare crank and spare pistons to use. i have also already bought rod bearings for it... ask for money, i've already spent about 550 bucks on this project (not counting the first 90 dollars in gaskets from earlier) so i don't have the cash to dish out for another engine (tho if i woulda known this would be the case i woulda gotten like a z6 or y8 or hell a ZC if i could) so i think i'm just gonna finish this up. i have left to buy the main/crank bearings (30), piston rings (50), and i'm also gonna place the timing belt and the rest of hte belts while i'm in there, so i have about another 150-200 in parts, then i have to rent a hoist and stand and get it all together again... as for a hone job, the walls look damn good so i don't think i need that. if i'm missing anything tho, or if someone has another engine they are willing to trade for everything i have (one complete motor which is taken apart [intake, head, and exhaust are all together and the block is almost completely disassembled] and a complete, disassembled block which needs a hone job, all this minus a rod, oh and a head gasket) for a complete, running engine (anything i can swap in), then lemme know...
Old 07-19-2003, 10:38 PM
yeah its understandable in that case... as soon as i started to see what all was bad when i tore my a6 engine down i wrote down all the the parts needed and got the cost of that and the cost of a zc, the zc was way cheeper... now i'm rebuiling parts of the tranny haha
Old 07-20-2003, 01:06 AM
Jay eS Iye's Avatar
well now that i've gone into the engine and i'm a little more aquainted on how things work, i'm gonna look more into everything next time i have a problem... first tiem for everything i guess
Old 07-20-2003, 01:43 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
what are the symptoms of a bad rod bearing ?
Team Lonely Drivers
Old 07-20-2003, 02:20 AM
91civicDXdude's Avatar
knock, knock...
who's there?
knock knock knock knock, kaboom
Old 07-20-2003, 02:39 AM
like a really really loud knock, one thats louder than my open header. a knocking sound that comes from behind or underneath the engine ?
Team Lonely Drivers
Old 07-20-2003, 01:13 PM
Jay eS Iye's Avatar
or your car just won't run one way to check, take off oyur oil pan and look for metal shavings... i know that b/c on the side of the oil pan where i had the bad bearing there are alot of shavings...
Old 07-20-2003, 03:17 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
its a LOUD ass knock u will forsure know somethin is wrong
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 07-20-2003, 03:20 PM
hmm i got a loud ass knock, louder than my open header. dammit
Team Lonely Drivers
Old 07-20-2003, 03:21 PM
H4Bangin's Avatar
do u still have power?
Old 07-20-2003, 08:42 PM
it starts off as a quite knock though and over time it gets louder and louder, till it scares the bejesus out of you and then the car just won't run... haha best part is when mine stopped working i ran a 16.2 1/4 mile time haha
96 Eclipse 2.0 Manual Wheel Bearing Question AdrianT Eclipse Problem Diagnosis 1 09-20-2010 08:05 PM
ROD BEARINGS has anybody tried? Chuckmonster Caravan | Voyager 1 07-27-2009 07:50 PM
Rod Bearing Question dotfixer Maintenance 1 03-06-2005 07:07 PM
help me PLEASE! Twin Cam thrown Rod c0rx10 General Discussion 7 11-04-2004 10:02 PM
thrown rods And1fixer Corolla/Matrix/Voltz 2 09-02-2004 07:14 PM
