Old 07-18-2003, 09:10 PM
IBLDHP IBLDHP is offline
Help!
ok, i bought a wrecked 92 RS camaro last year that ran untill i pulled the radiator to put a front end on it...i put it on a frame machine and straighted the frame and welded in a new radiator support...after getting most of the front end put together and a new radiator in it...i drove it to a body shop here in town...after sitting at the shop for a week he pulled it outside to re-arrange the cars his shop and it wouldn't start when he went to put it back in...i've changed the distributer, plugs, injectors and can't figure it out..it gets fire to the plugs and now there is gas in the oil...only thing i can think of might be the fuel regulator in the throtle body is messed up and dumping a bunch of fuel in the motor fouling the plugs...any ideas?? thanks
Old 07-20-2003, 04:59 PM
anyone??
Old 07-20-2003, 05:25 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Sorry man.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 07-21-2003, 02:06 PM
well its not the regulotor i put a new regulator in it must be a sensor or a relay or something...really getting aggravating
Old 07-21-2003, 10:04 PM
pcv pcv is offline
Only thing I can think that will cause your problem is the coolant sensor, reading cold and dumping fuel into the cylinders. Pull all the plugs out, dry them. Let the cylinders dry for about an hour, Reinstall the plugs. Change the oil and filter. With your gas pedal to the floor, start the engine. It should start. If not get it scanned and look at the readings. You might have the tps of the coolant sensor out of specs. Good Luck.
NOTHING LIKE AN OLD CAR.
Old 07-22-2003, 03:32 AM
thanks alot...one more thing i thought the motor had to run to scan it?
