Old 07-18-2003, 10:11 AM
cornbread499 cornbread499 is offline
D16y7 Non Vtec engine swap?
I found a newer engine today to put in my Civic DX. It's a d16y7 engine I know it doesn't have vtec and that is fine wit me because my d15b2 has over 211K on it and that is alot. Now the d16 is only going for $200 without tranny. It is stock and only has 40K on it which means it is barely broken in. I plan on building it up with the basics and alittle internal work. My question is with the swap, do I only have to swap from Dpfi to Mpfi? Will my dx ecu work with this and will my dx tranny bolt up to it or do I need something else?
Old 07-18-2003, 10:20 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
you dont 'have' to swap to mpfi...but I would..especially if you're building it up... you'll just have to use your intake mani off your dx..
your tranny will bolt right up...
SOLD!
Old 07-18-2003, 10:32 AM
Definately swap to MPFI. How much more power over my old engine do you think I will have? I'm just going to get the basics to start off with I/H/E. Also I plan to get my muffler shop to build me an full exhaust system with magnaflow cat. What is the best piping size to use for an all motor car?
Old 07-18-2003, 10:36 AM
marked001's Avatar
Moderadur
whoops..I reread your question... your dx ecu will not work, you'll need a si ecu (pm6) plus a injector resistor box and some 88-91 injectors... (you cant use the ones that come with the new engine)...
I'd go with 2.25" piping...
SOLD!
Old 07-18-2003, 11:17 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
the y7 produces 106hp
2002 Acura TL Type S
1991 Honda Crx Si
Old 07-18-2003, 11:26 AM
4g4d_getone's Avatar
4g4d_getone 4g4d_getone is offline
yeah u have to swap ecu's u might b able to keep ur dx harness and definetly swap out the dpfi for the mpfi.
Y LOOK FAST WHEN YOUR NOT?????????
Old 07-18-2003, 11:32 AM
90civichatch 90civichatch is offline
Send a message via AIM to 90civichatch
What car is a D16Y7 from?
-Derek
1990 Honda Civic Shit-box, Sold.
Old 07-18-2003, 11:34 AM
marked001's Avatar
Moderadur
96-00 dx I believe....
SOLD!
Old 07-18-2003, 12:17 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
96+ Civic CX
96+ Civic DX
96+ Civic LX
1590cc
4 cyl, 16 valve
SOHC
9.4:1 c.r.
PGM-FI (MPFI)
Power: 106 bhp @ 6200
Redline: 7100 rpm
Torque: 103 lb-ft @ 4600
marked001 you should know it's MPFI
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 07-18-2003, 12:33 PM
marked001's Avatar
Moderadur
I never said it wasnt!
SOLD!
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
anyone have any info on a f22a non-vtec head swap to a f22b sohc vtec head mox4_2001 Let's get Technical! 3 06-27-2004 07:46 PM
Non-vtec/vtec engine swaps Parsalian05 Prelude 0 09-01-2003 04:02 PM
can you vtec a non vtec engine? Crxce '88 - '91 Civic | CRX | Wagon | Shuttlee 7 03-20-2003 11:54 AM
