Old 07-18-2003, 07:28 AM
canul8r canul8r is offline
Exclamation Hot under the collar but not under the hood
I have a 97 Blazer and was wondering what may cause
1. The temp gauge to read low 140 - 150 while cruzin down the road
2. The temp gauge to read around 250 while ideling and in drive
3. The temp gauge to drop to around 180 while ideling and in park
4. And finally, why does it sometimes blow hot air out of the heater when set in the heater position and then other times cool air
Any Ideas?
Old 07-18-2003, 12:10 PM
Tillman Tillman is offline
Lightbulb Crazy from the heat
The heat from the heater comes from the water your temp gauge is supposed to read. If the air feels hotter when the gauge reads high, and cool when the reading is low, the gauge may be correct. I've never heard of a sticky themostat, but I guess it's possible. I'd also check the fan. Hope that helps.
Old 07-30-2003, 11:30 AM
jamaicajn jamaicajn is offline
Hi..I have the exact same problem. No one yet has an answer
Old 07-30-2003, 01:39 PM
jaabou jaabou is offline
i had a similar problem, do you have that orange coolant in the radiator?
if so, get rid of it. The orange coolant over time it turns into sludge/rust color. Flush out your whole system, ratiator, hoses, engine, and dont forget the overflow. And fill it up with the regular "GREEN" coolant.
U Guys Can View The Shit But Not Respond??? Then Wtf Is The Point Of Even Lookinat It badassfocus1101 F Series 9 11-28-2005 09:36 PM
Brake Issue. I know the problem but not the resolution riojas Caravan | Voyager 1 05-21-2005 03:18 PM
I want the motor, but not the SC body RickwithaTbird Thunderbird 15 01-28-2005 10:20 AM
Car shifts fine at Wot, but not under normal load jimmy9482 Camaro Discussions 0 08-02-2004 06:42 PM
new to the scene, but not to the game!!! crxsi_ls General Discussion 2 05-11-2004 05:40 PM
