Old 07-18-2003, 12:42 AM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
damn stuck crank...
i'm trying to turn the crank with a ratchet but it won't budge (my dad is telling me when i got hte car back from the shop they said the block was seized up). now how can i break it loose if its really seized, or will it not turn in its current state. right now i have the top half all off, and the oil pan and cover above the rod caps are off. and i'm trying to undo the caps and take out the pistons so i can change out the bearings and hopefully get my car runnin again. but i can't take everything out until i get it to TDC. lemme know what i can do.
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 07-18-2003, 12:55 AM
BullShifter's Avatar
If the engine is seized one or more pistons is most likely to be completely stuck solid.
Old 07-18-2003, 08:42 PM
Jay eS Iye's Avatar
ok but how do i get them undone? i know there has to be a way.
Old 07-18-2003, 08:48 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
try applying some liquid wrench where it meets the cylinder wall. That shit really does work good. I dunno though, thats just a suggestion.
Old 07-18-2003, 08:50 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: damn stuck crank...
Why do you have to have it at TDC to take apart the motor? I rebuilt my motor and didnt to any TDC positioning until it was all put back together..
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 07-18-2003, 11:22 PM
Jay eS Iye's Avatar
well i have the block still in hte car so i have little room to work with, and even if its not needed at TDC it makes it alot easier. but i got it, i just cranked it by using the key to "turn it over" tho i know it wouldn't do anything. i just kept cranking it little by little until it broke loose.
go the pistons out too, and found the problem. the bearing in cyl 1 (i think thats the one on the far driver's side) was completely shot and the rod was bent too... never would i think that could look so good but i know now the problem, and i have spare parts for it too, i just hafta check the crank to see if the shot bearing messed up the surface on hte crankshaft... anything else i should check? and another off topic question, when i put it together, do i need to replace the piston rings? how do i tell if they are bad?
Anti-Theft Window Crank Device ? Intuit Escort 6 10-11-2011 02:00 PM
96 Taurus slow cranking bukuballs Taurus | Taurus Wagon 6 06-07-2011 06:25 PM
1998 Express Cranks but no Start kmckev2 Express | G Van 5 01-07-2010 11:26 AM
2000 gtp - crank sensor replacement kozmosis Grand Prix 2 08-27-2009 10:18 AM
92 ex timing belt not lining up at TDC (cam pulley/crank pulley) Swansen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-01-2009 11:02 AM
