Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 07-18-2003, 12:22 AM
lenouveaujvo lenouveaujvo is offline
Installing Alarm In 1997 328i
How difficult is it/what exactly is involved in installing an alarm w/ keyless entry in a 1997 328i?
Thanks,
Jeremy
Old 07-18-2003, 12:49 AM
zachseemsforever zachseemsforever is offline
Smile
dude,
i just installed a keyless entry in my 97 328is. it was easy, even tho im electronicly illiterate. it took me 3 hours, but would only take about 1 now, maybe less. first you take out the glovebox. find the alarm wiring harness (under a buncha wires in the left center.). unclip the harness, and pull it out as much as possible. print off the diagram of the wires from this webpage.
http://www.autotoys.com/New_Tech/Mis...ody_balarm.htm
then cut the wires your alarm needs and wire them to the alarm. you may need a positive door lock changer for your keyless entry. make sure it works, then close it all up. its not nearly as hard as you may expect..... if u run into any problems, email me @ [email protected]
Old 07-18-2003, 11:22 AM
Thanks
Thanks a lot. It may be a couple weeks before I actullay get the alarm, but I'll e-mail if there are any problems.
--Jeremy
Old 08-01-2003, 02:09 PM
98328i's Avatar
98328i 98328i is offline
Send a message via AIM to 98328i
Cool Alarm Wiring Diagrams
Let me know if you should need any wiring schematics to your car or any car I have a login to the DEI (Directed) website and I can get you location of any wire pertaining to alarms or remote starts or just easy keyless entry.
1997 Tercel alarm resets when battery disconnected Simstim Tercel 3 01-10-2010 03:36 PM
alarm system 328I paulboudreau 3 Series 0 09-29-2007 02:39 PM
1997 328i Rear shocks.How hard? BulletTooth 3 Series 8 02-01-2004 03:26 PM
1997 328is need info powell 3 Series 1 06-02-2003 10:01 PM
My 1997 328is is it a lemon?? rjs5689 3 Series 4 11-15-2002 03:32 PM
