Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 07-17-2003, 11:24 PM
court65 court65 is offline
215/40/17zr on a 2002 dodge neon sxt
I bought some wheels that are 17x7 with a offset of 40mm the stock wheels on my neon is 15x6 with a offset of 35mm, are there going to be any problems fitting these and what are thier solutions and also will my tire choice of 215/40/17 be a problem? any help thanx
Old 07-18-2003, 01:13 PM
Cy@tirerack Cy@tirerack is offline
We offer 17x7 of 40mm offset as well so you should not have a fit problem. Performance wheels tend to have a lower offset for better looks and performance.
We recommend 205/40-17, 215/40-17 may rub. I would not recommend that size unless you are aware of other Neon owners running it. You can check with them at Neon portion of this site or other Neon specific sites.
Old 07-18-2003, 03:58 PM
Would you recomend the use of wheel spacers or a wheel adapter that would give me enough clearance to have a bigger tire selection? Because i have seen the B&G neon with a tire size of 215/35/18 and hey look incredibly snug.http://www.sportcompactcarweb.com/fe...rph/index.html
Old 07-18-2003, 04:24 PM
We're not big spacers fans because it's difficult to use them correctly because of lug/bolt & stud issues. We don't recommend them, we focusing on having wheels with the correct offset available.
If you need clearance to the outside you can roll the fender lips. See:
http://web.tampabay.rr.com/actionfit/fenderolling.html
[email protected]
Old 07-18-2003, 10:36 PM
It looks like a real good solution but if the wheels are grinding against the springs or something else in the back then fender rollng wont do much except give me more wheel space for wider wheels. Are there any places around Connecticut that you know of that can do this process or where I could get tools to perform this?
Old 07-19-2003, 04:24 PM
We have loaner fender lip rollers available like the one pictured. To loan one out we would charge $495 plus shipping as a deposit. You would then have 3 business days to us it. As long as return with 3 business days you would only be responsible for shipping costs.
[email protected]
Old 07-20-2003, 03:59 PM
That is real expensive for a loaner. I could get my fenders cut or rolled for much less than that without having to do it myself. Or I could get a race fender which is really wide and mold it to the stock front and rear fenders and have 17x10 with wide race fenders. Maybe I could get those M3 race fenders from a BMW and custom tailor it to make a widebody kit for my neon?
Old 07-21-2003, 08:05 PM
We don't actually charge $495 - it's a deposit that you get back when you return. You're just responsible for inbound & outbound shipping - figure $25-$30.
[email protected]
Old 07-21-2003, 09:48 PM
Now that sounds good but now I have to find a way to make the fenders look wider to cover the wheels because it wold'nt look right with the wheels sticking out looking like a open wheel racer.
HELP!! 2003 dodge neon sxt lacieb 2nd Gen 00-05 2 05-02-2007 11:28 PM
2005 Dodge Neon SXT TheNotoriousMogg 2nd Gen 00-05 2 02-02-2006 12:33 PM
Dodge Neon SXT fraggle Car Modeling 12 01-15-2004 09:01 AM
Ive done some research will this fit on a 2002 dodge neon sxt? court65 Tires and Wheels 1 06-18-2003 06:30 PM
