Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 07-16-2003, 06:41 AM
eli eli is offline
Problems With Sonata 2003 Gls V6
I have purchased the sonata 2003 V6 GLS, after 1000 mills the car started experiencing loss of power and when going up hill in third gear around 30-35 mills per hour, loss of RPM and power, adding gas would not result in addition of RPM and power, the car would increase speed slowly and when reached to around 40-45 mills per hour the RPM would suddenly go height, still in third gear, then switched to fourth gear. In addition spars have black carbon deposit on the inside of the plug, not on the conductor and insulator. Recently the car is bucking on the highway every now and then. Went to two dealers, computer does not show any code and they are dismissing all this as something being wrong with the car. ANY IDEA?
Thanks.
Eli
Old 03-30-2004, 05:30 PM
tuckers04sonata tuckers04sonata is offline
Re: Problems With Sonata 2003 Gls V6
I would keep taking it back, make them ride with you to show them the problem.
Old 03-31-2004, 01:21 AM
tibby01 tibby01 is offline
could be a MAF or MAP problem.
maybe TPS problem. or o2 sensor problem. just tell them to check all the sensors.
Old 04-04-2004, 08:30 PM
wpbharry wpbharry is offline
After attending the West Palm Beach Auto Show today, the '04 Sonata LX is now on my short list.
You might want to check Edmunds.com's Town Hall posts for ideas on your problem. This sounds familar... I don't recall what it was though.
Old 05-28-2004, 05:58 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
fuel injection cleaning,preferbly profetional one,bucking,loss of power,are all syptoms of clogged fuel injectors,also your air filter,and plugs
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Various problems with my 1992 Nissan Sentra XE (4 door) benenarmor Sentra | 200SX (USDM FWD) 0 10-11-2009 12:32 PM
2 problems with me 2003 Dodge GC Sport OSUCowboy27 Caravan | Voyager 17 02-02-2009 06:47 PM
Problem With Brakes 2003 wldwest75 Windstar 4 03-29-2005 12:54 PM
I'm Having Bad problems with my 2003 G35 Creigh General Discussion 4 12-01-2004 09:20 AM
Bad Problems with my 2003 G35 Sports Coupe! Creigh Nissan 350Z/370Z | Infiniti G35/G37 Coupe 3 02-27-2003 12:29 PM
