Old 03-23-2005, 10:27 PM
wldwest75 wldwest75 is offline
Question Problem With Brakes 2003
i have been having problems with the brakes, Replaced brake pads, wich they were really bad. It pulls itself when you have the brake all the way down. Any suggestions on what might be thr problem?
Old 03-24-2005, 05:54 AM
DRW1000 DRW1000 is offline
Re: Problem With Brakes 2003
Have you narrowed it down to the brakes?
Total guess but it might be that the brake on one side grabs more than the other and thus the pull. Perhaps there is air in the brake lines on one side or contaminated fluid.....
It could be another part of the front wheel assembly too. Even the transmisiion.
Old 03-24-2005, 08:34 AM
garync1 garync1 is offline
I guess you mean it pulls to one side.. If it pulls to the right or the left. You may want to bleed the brakes first. Start from the back panssenger side to the back drivers side then passanger front then the drivers side front.Make sure you dont run the fluid out of the fill tank. Also the very first thing I would do is to drive very slow down a road close to you for about 1 minutes time dont use your brakes. If so as little as possable. check to see if one weel feels hot.If it does you may have a sticking caliper. Did you notice if one side rotor was worn more than the other??
If the rotor did not show exssive wear than try the bleeding process first . Hope this helps ..Gary
Old 03-25-2005, 08:32 AM
I went ahead and put it in the shop.luckily it is still under warranty.So we will see what they say. Thanks for the help though, I appreciate it.
Old 03-29-2005, 11:54 AM
Well it turns out it was the brake booster.They put a new one on and the brakes are good now.
