Old 07-16-2003, 03:52 AM
cmsjac cmsjac is offline
94 Keyless programming instructions
I just bought a 94 Pontiac Grand Prix which had the remote for the keyless entry missing, I have located a remote but do not know how to program it.
Anyone have any idea on what I have to do to program the remote?
Thank you!
Old 07-20-2003, 03:22 PM
GhostLake GhostLake is offline
You might try this. I tried it on my 92 but it didn't work. I think something is wrong with the receiver.
1. Open trunk lid. Remove right side rear compartment trim. Using a jumper wire with alligator clips ground transmitter program wire terminal. Door locks will lock and unlock, indicating receiver is in program mode.
2. Depress and hold any button on one transmitter. Door locks and truck lid release should activate in about 2 seconds. First transmitter is now programmed. Repeat this step using other transmitter. If only one transmitter is being used, disconnect jumper wire.
Old 07-29-2003, 01:14 AM
Transmitter won't stay programmed
First of all, thanks for your help - it worked!! Until the next morning when the transmitter wouldn't work the locks, so I re-programmed it again which worked for about a minute then stopped - so I went & replaced the battery's in the transmitter & re-programmed again, but still it only worked for a couple of minutes & then no longer responded .
Anyone have any ideas?
Old 08-07-2003, 02:57 AM
supreme_style21 supreme_style21 is offline
Send a message via Yahoo to supreme_style21
Sounds like the keyless entry module is going bad.. Some resoldering will fix that up.
justin - '94 GP SE sedan - '89 GP LE coupe
Old 08-07-2003, 06:24 AM
Know where this module is located?
Old 08-07-2003, 01:10 PM
I know for sure that on the older model GP's, the module is on the right side, under the rear window deck lid, so I would assume it is the same for the '94.. if not, it's under the driver's instrument panel.
Here are instructions on how to fix it:
http://www.w-body.com/service/keyless-entry.html
Old 08-07-2003, 01:17 PM
1998 Toyota Avalon XLS Keyless Entry Programming Instructions kattate09 Avalon/Pronard 1 02-04-2010 04:58 AM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless program instruction for avalon 2002 toyavalon Avalon/Pronard 3 09-01-2004 01:05 AM
1995 Buick Roadmaster keyless program instructions topbuyer General Discussion 1 02-13-2004 11:35 AM
Keyless Programming Instructions 3000GT lockmart1 3000GT/Stealth 3 11-06-2003 09:43 AM
