Old 07-16-2003, 02:10 AM
fredo fredo is offline
How to clean airbrush with Future ?
I plan to try airbrushing Future Klear with my airbrush. But what must I use to clean the airbrush afterwards ?
Water ? (I read in the FAQ that Future is a sort of acrylic clear coat) ?
Isopropylic Alcool ?
Is it necessary to thin it or are you using it directly ?
Thanks
Frederic
Old 07-16-2003, 02:45 AM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
Water to rinse out the residue, then isopropyl alcohol to make sure its clean.
Old 07-16-2003, 10:18 AM
doraemon doraemon is offline
If its an acrilyc one like tamiya's you must thin it before apply it, and for clean the airbrush I use 96º alcohol (pharmacy one) its cheaper than isopropyl, and after this, if you want to take out the high dry grade of the alcohol, use a little of water and spray a little, its what I do, and the airbrush remains perfectly cleaned.
Old 07-16-2003, 10:19 AM
freakray freakray is offline
AF Modelrater
A good ammonia based window cleaner will also be good to clean the airbrush.
AF User Guidelines
Old 07-16-2003, 02:51 PM
935k3's Avatar
935k3 935k3 is offline
Use straight ammonia for cleaning and stripping Future(Johnson's Klear)
Old 07-16-2003, 03:06 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
I always clean my Paasche airbrush with Denatured Alcohol (pure). this is the best for any Acrylic. But im sure Syndicate has some really dangerous way to do it sorry syndicate, just thought back to the lighter fluid thing...worst thing is... i tried it and there really arent fumes! but this is for enamel.... USE DENATURED ALCOHOL for Acrylics!
how do I keep a clean line with two-tones? Sixx Car Modeling 9 05-12-2008 08:01 PM
Gasket Surface How clean Is Clean? Blownpiston Century 2 03-16-2008 10:27 PM
cleaning airbrush.. ktan Car Modeling 7 05-05-2003 05:46 AM
Learning how to Airbrush..Got a quick question ;) Jinxed Car Modeling 10 09-25-2002 12:09 AM
Cleaning Airbrush after Lacquer use?? djmr2 Car Modeling 9 09-23-2002 07:49 PM
