Go Back   Automotive Forums Car Chat > Buick > Century
Old 03-15-2008, 03:24 PM
Blownpiston Blownpiston is offline
Question Gasket Surface How clean Is Clean?
Replacing cylinder head gaskets,on 3.1. I have used plastic scrapers, aerosol gasket remover, brake cleaner, and acetone. No grease, oil, or dirt left on surface. It is not super shiney as when head is milled. still see some blackness imbeded in metal. No ridges, or high spots. Is this normal? And o.k. to install gaskets? This seems dumb question, but here on forums i see all the time where, everyone says clean,clean, clean!! Thank You all. GOT IT ! There will be discoloration of the metal a little. Unless you are machining the head. So, looks like i got it VERY clean, and can go ahead and install it. Thanks guys.
Old 03-16-2008, 03:56 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Gasket Surface How clean Is Clean?
If there are no high spots and all the grease and oil is removed you are clean enough. The major issue is to make sure that there are no parts of the old gasket material remaining and that the surface is clean. This goes for both the deck and the head. This applies to all other gasket surfaces as well.
Old 03-16-2008, 10:27 PM
Smile Re: Gasket Surface How clean Is Clean?
GTPdad, Thank you. I can rest a lot easier now, and have confidence in this replacement. I learned something new!
