Old 07-16-2003, 01:09 AM
lowboy lowboy is offline
Send a message via AIM to lowboy
Whats the Difference Between....
whats the difference between 205/40/16 and 225/50/16 sized tires???
is it width or rubber grade?
Old 07-16-2003, 01:18 AM
swedish swedish is offline
205/40/16 = 205mm wide tread, 40mm tall sidewalls, and a 16in inner diameter
225/50/16 = 225mm...
rubber grade is determined by letters, and you'd have to ask someone w/more knowledge than me to get the run down on that
"One great big festering neon distraction,
I've a suggestion to keep you all occupied.
Learn to swim."
Old 07-16-2003, 01:22 AM
i guess what i was asking is whats the difference between the 225 and the 205
also will the size of my rims effect the calibration of my spedometer?
Old 07-16-2003, 01:45 AM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
THE 40 DOES NOT MEAN IT HAS A 40MM SIDEWALL!!!!!!
IT MEANS THAT THE SIDEWALL HEIGHT IS EQUAL TO 40 PERCENT OF THE TIRE'S WIDTH!!!!
Old 07-16-2003, 02:39 AM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
225 is much wider than 205, and the size of the rim could affect your your speedo, but it all depends on if you get the right size tire.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
whats the difference between the 4t40e and the 4t60e aptyk88 Grand AM 1 01-13-2008 05:34 PM
Whats the difference between the different models? Jaxal General Discussion 0 02-10-2007 11:45 AM
Whats the difference between the 68 chevelle and the 68 beaumont????? thetaz_31 Chevelle 5 07-22-2006 07:34 PM
whats the difference between the ecu and the eprom? BlackShadowTSi Off-Topic 11 06-15-2004 01:23 PM
whats the difference between a 528i and the 528ia? hewtash 5 Series 4 05-19-2004 01:23 AM
