Go Back   Automotive Forums Car Chat > Suzuki > Vitara
Old 07-15-2003, 09:50 PM
vmarrtin vmarrtin is offline
1999 Grand Vitara
I also have the same problem, The remote on my 1999 Grang Vitara is broken and I purchased 2 new remotes from the dealer. How do I go about reprograming my remotes?
Old 07-21-2003, 02:50 PM
I got my remote programed. just in case anyone need help reprogramming they remote, it goes as follows:
(1) find your keyless module ( on the Driverside under the dash). on the module to the right of the wire harness and the left of the LED , is a switch.
(2) turn the key to the on position for 3-5 seconds then back to the off position.
(3) the switch between the wire harness and the LED. using a small screwdriver push down on the switch the Led light will sound and start flashing, press the lock on each remote your programming, wait 5 seconds after the last remote and push down on the switch on the module the flashing tight will go out. pragramming is complete, you can program up to 4 remote.
1999 grand caravan se 3.3L HEATER Tyson_baker Caravan | Voyager 4 01-24-2011 03:24 PM
1999 Grand Caravan A/C Evaporator Core diagram ecrumb Caravan | Voyager 4 07-12-2010 08:04 PM
1999 Grand Am nanatraci Car Audio 5 06-19-2009 07:00 PM
1999 Grand Vitara v.s. 1998 ford explorer Floyd77 Vitara 0 01-30-2004 02:41 AM
Grand Vitara and XL-7 Swoxy Vitara 1 10-14-2003 08:29 PM
