Old 07-15-2003, 07:09 PM
Grallim Grallim is offline
adding horsepower
Hello,
I have a 1992 Honda Prelude with an AEM cold air intake, and an exhaust that runs from the headers back. I'm looking for ways, such as bolt ons, to increase my horspower because I do not wish to rip apart the block and start replacing stuff do to the lack of large amounts of money. Does anybody have an suggestions for me??
Phil
Old 07-16-2003, 02:42 PM
9-deuce 9-deuce is offline
Send a message via AIM to 9-deuce Send a message via Yahoo to 9-deuce
you could pull your emblems off and put em on an integra
J/K dood work on your timing, get a throttle body, intake manifold,-should give it some extra nutz
To my homeowners assosiation:
1. sorry for the noise
2. sorry for the noise
3. no I have not seen your cat
Old 07-16-2003, 03:27 PM
99civic03's Avatar
99civic03 99civic03 is offline
Send a message via AIM to 99civic03
Get a new ECU.
Old 07-16-2003, 03:33 PM
buymeabmwm3 buymeabmwm3 is offline
NOS. At least 1000 shot. And lots of stickers.
1992 BMW 325i conv.
FOR SALE!!
IM me for more info. $6300 /obo
2005 Ducati Monster 620 i.e.
2005 Toyota Tacoma V6 4x4 Double Cab, TRD Off-Road - FINALLY HERE!
Horsepower is 100 ewoks poking you with pointy sticks.
Torque is one wookie pulling your arms out of their sockets.
Old 07-18-2003, 10:07 AM
89B18C1CRX 89B18C1CRX is offline
Send a message via AIM to 89B18C1CRX Send a message via Yahoo to 89B18C1CRX
Well first of if you only have intake exhaust you might as well complete the set and get a decent set of headers to add on. Then id go with some underdrive pulleys to lightin you up and help on timing. Then also the throttle body idea woudl be nice wiht a nice spacer, also intake manifold. You could also upgrade your injectors fuel rail and things along those lines. Defidently dont get all cheezy and throw NOS in yoru car and blow a good honda to pieces trying to be alittle ricer. Also new clutch and flywheel are good add ons. Not saying you will get a huge increase of noticable power, but two very good ad-ons for a well built car.
Lets line um up biatch!
Old 07-18-2003, 11:40 AM
CRX, can you add a lightened flywheel and an underdrive pulley on the civic? On my E30, the combination of the two is commonly known to cause crankshaft problems.
1992 BMW 325i conv.
FOR SALE!!
Old 07-18-2003, 11:44 AM
Yes you can add both its a very good combination because it allows for quick reving. Ive never heard of an irregualr cam wear.
Old 07-18-2003, 03:37 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Start with only one header, he doesn't have a v6.
The pulleys/cam sprocket are pretty expensive, but damn just an underdrive pulley and sprocket added 9 wheel hp on my civic DX. On a lude I'm sure it'd be around 15 or so, and yeah it's noticeable. Don't worry bout the header, that's ~$400 for 5-7 hp... not worth it in my opinion. I love the older preludes, even the non vtec's are pretty quick stock.
Old 07-19-2003, 09:50 AM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Ok 1st the underdrive pulleys are a good idea except fr the crank shft pulley, leave it stock. I fyou change the crank shft pulley then you will be destroying the bottom ends strength.
2nd the "NOS" comment is far off and it is not "NOS" it is nitrous rice boy! I have been using nitrous for almost 3yrs now and my motor is still on the stock internals and has over 130K on it. The compression is almost to spec and that is with 3yrs of nitrous and 130K miles. So don't go around spreading misinformation that you obveously have no knowledge of.
Old 07-20-2003, 05:20 AM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
Re: adding horsepower
Originally posted by Grallim
Hello,
Phil
Maybe you should post questions about Preludes in the Prelude-Forum next time!?! YouŽll definetly get some better answers there...
@89B18C1CRX: New fuel rail and injectors are a waste of money on an engine with just some bolt-ons.
Old 07-22-2003, 06:25 PM
TuRboVrOoM TuRboVrOoM is offline
i personally really dont think intake header exhaust gives you power it just frees up the air and free up the power you already had. As for going fast your need to
1 strip car
2 New crank
3 new rods
4 new pistons
5 new cams
6 new valves
7 new valve springs
8 titanium retaniers
9 bore throttle body
10 intake manifold and pulleys and cam gears
11 ingnition system
12 injectors
13 stage 3 clutch and take your flywheel to a machinist and shave to 14.7 lbs your stock flywheel is stronger than many aftermarket
14 fuel rail
15 fuel pump
16 Turbo kit with intercooler
17 nitrous kit
18 reflash your ecu
19 blance and blueprint engine
20 tune your engine
21 Take it to the streets by now you should hope fully run some nice 11's
But hey lol what do i know about building a engine i just only went to uti and work for a engine shop
Dont take my word for it.
Old 07-23-2003, 03:36 AM
strodda strodda is offline
no offense, but thats just stupid. you say to upgrade all the internals, and you expect the engine to breathe with a restrictive stock box and a small exhaust. i can only imagine the great amounts of power youll get from a turbo system letting out to a stock catback. what you need to do is get the i/h/e before anything else is worked on. and it does add power. if the power was there to begin with, then there wouldnt be any increases.
#'s 9 and 10 are great. lets get an intake manifold, port match it to a bigger tb and then feed it with a stock intake. sounds like a winner to me
Old 07-23-2003, 07:18 AM
1 strip car
2 New crank
3 new rods
4 new pistons
5 new cams
6 new valves
7 new valve springs
11 ingnition system
12 injectors
14 fuel rail
15 fuel pump
17 nitrous kit
18 reflash your ecu
20 tune your engine
I think you kinda forgot what this thread was exactly about buddy. If you didnt ready he said that he was lacking a lot of cash flow, and your over here talking abotu rebuilding the internals and adding turbo and nitrous? Damn man unless you are lending out the cash flow to do that last time I checked it isnt very cheap to rebuild all your internals. And secondly last time I checked by freeing up airflow and gas amounts is how you increase hp. Therefore by adding i.h.e you are adding hp, for working in a engine shop and saying that you dont need i.h.e, and that they dont increase hp your pretty dumb.
Old 07-23-2003, 08:46 AM
Ricochet's Avatar
Banned
He was correct about i/h/e "freeing up" hp the engine already has, all they do really is suck in/expel air more efficiently. On a Prelude these three will free up about 15 horsies.
Old 07-23-2003, 10:20 AM
Veetec's Avatar
Very true!!
How to increase horsepower? matt9214 Engineering/ Technical 1 09-09-2009 09:03 PM
Adding Horsepower - how much does if effect transmission jer_bond Oldsmobile Classics 7 04-30-2008 02:49 PM
Adding horsepower shockclyde Dakota 0 09-16-2007 08:39 PM
Adding Horsepower!!! likin8 Grand Prix 16 01-07-2006 07:31 PM
A Big ad!! (Single greatest T.V ad in history) -Davo COMPLETELY off-topic 25 07-30-2005 02:29 PM
