Old 07-15-2003, 03:23 PM
bluesaltfisher bluesaltfisher is offline
Red face air conditioner
the airconditioner in my 93 s-10 blazer isn't cooling like it should. when I turn it on it is really cold for about 5 minutes, but then it blows what feels like vent air. My mechanic recently recharged the system(april 2003). I took it back to him last week to check the freon levels, and he said it was fully charged. he suggested that it was freezing over and that was why it will blow warm air after awhile. Any suggestion on how to solve this problem? I sometimes turn it off for a few minutes and then it is cold again, in the meantime I'm sweating bullets.
Old 07-16-2003, 04:40 AM
cobra1 cobra1 is offline
open the hood and start the vehicle. after it starts blowing warm air, check to see if the compressor is cycling or not. you'll be able to tell if it is, as the clutch makes a noise when it engages.
if it is not cycling, look to the left and you will see the accumulator (aluminum cylinder), mounted on this will be a pressure switch. disconnect this switch and use a piece of wire or paper clip and jump the two terminals in the wire harness. if your compressor cycles then you probably need to replace this switch. it unscrews from the accumulator, and where it unscrews from should be schrader valved, at least it was on my 95 s-10.
i had that same problem on my s-10, it would work for a while and then quit. the pressure switch fixed it.
remember though, all this is assuming that your system is properly charged. if it is overcharged, it could be freezing up. however if it has been hooked up to gauges and everything reads fine pressure wise, then id say its most likely the pressuere switch.
Old 07-16-2003, 08:11 PM
bigblackone bigblackone is offline
if you still have the stock fan - you might want to check the fan clutch as well ....
Old 07-17-2003, 02:45 AM
a faulty fan clutch will have no effect on his problem. 5 min would never be long enough to heat up enough to engage the fan clutch anyway.
Old 07-17-2003, 02:48 AM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
off-topic kinda
but my ranger is doin the same thing
so would those tests work on a ranger?
thx alot
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 07-17-2003, 04:07 AM
im not sure how Ford's systems are set up....so its hard to tell
Old 07-17-2003, 04:18 AM
Jetts's Avatar
k cool thx anyways
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
HELP!!! 02 Buick Lesabre Air conditioner broken 02BuickLesabre LeSabre 6 08-17-2010 05:41 PM
Air Conditioner Compressor Cycling On and Off mafiadoller Silverado 6 06-06-2010 08:55 PM
95 civic air conditioning issues reverend jim '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 08-17-2009 05:18 PM
98 Blazer - Air Conditioner Blows Outside Air cwa92464 Blazer 1 01-03-2004 09:25 PM
