Old 06-06-2010, 01:21 AM
mafiadoller's Avatar
mafiadoller mafiadoller is offline
Air Conditioner Compressor Cycling On and Off
i have a 1993 chevy silverado with a 350 and i was trying to get the A/C to run cold,i put some refrigerant in the low side and it said that it was full.now the ac blows cool but not cold and the A/C compressor turns off and on in 10 second increments.i was wondering if i need to get a new compressor or what
Old 06-06-2010, 06:40 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Air Conditioner Compressor Cycling On and Off
having the pressures stated would help- but typically you are still low on refrigerant-- a gage cannot tell you if it is full- rapid cycling is an indicator of loss of refrigerant.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-06-2010, 08:30 AM
j cAT j cAT is offline
if you have the pressure at the low charge fittings and the a/c compressor clutch cycles this may be the low pressure cut out switch being out of range..see what pressure , that this switch causes the clutch to drop out..using a jumper you can test this, to be sure, the switch is not operating at the correct pressure.
what refrigerent are you using ? what is the OEM refrigerent listed for this a/c..
Old 06-06-2010, 02:25 PM
i am using r1234 refrigerent(it's been converted over)
Old 06-06-2010, 02:29 PM
the pressure is 45 psi, right before the yellow
Old 06-06-2010, 03:14 PM
since this was designed for the R12 the coils , the spaces between the coils are futher apart ..this reduces cooling efficiency with the conversion R134.
the coils being clean make a big difference ..
the switch ,,,the low pressure switch ,,with your pressure guage reading the low side pressures..with this connected this should not drop out with pressures above 5-10 psi..if the compressor shuts off at pressures above 5-10 psi jump out the switch and see if the switch is causing this..these switches do fail when they have been in service a long time..
Old 06-06-2010, 08:55 PM
i have not checked to see what the psi is when it turns on and off put i have jumped it off and the psi is 12(that's how i put the stuff in it,because it would not turn on by itself with out me jumping it off)
Tags
a/c , air , compressor , conditioner
