Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-15-2003, 02:44 PM
biggunner biggunner is offline
ECU errors, plz help (Misfire and knock sensor)
I checked my ecu this morning and recorded two errors on my 95 SE...
0304 - Knock Sensor
0605 - Misfire in cylinder 4
I have to definately address the misfire. To my knowledge, the most common source of a misfire is a bad injector or a spark plug. All six spark plugs have almost 20k miles on them, which leads me to believe that they are still good. But the previous owner of the car replaced a couple injectors as they went bad. Which is stupid, cause he should have just swapped them all, to avoid a paying 300+ dollars in service every time to take the manifold and the rest of the intake system off. I will probably do the service myself if I can figure out what the cause is. Any ideas or heads up?
As for the knock sensor. I use 93 octane, so is it worth replacing? I hope I'm not running a conservative fuel map or anything, that would suck. The lil' bastard is lodged way back under the intake. So myabe il do that if I take off the intake. Is cylinder 4 in the front or back bank?
Well, no matter what im ripping apart the max to figure this out. Just hoping if you guys have been through this before and can give me advice.
Old 07-15-2003, 03:04 PM
oh yeah, if anybody knows where to get cheap nissan parts, i.e. injector, knock sensor, plz tell me where.
Just dropped 400 on new yokohama tires, and need to save every penny.
Thanks
Old 07-15-2003, 05:11 PM
lordrashmi lordrashmi is offline
Don't worry about your knock sensor. In my experience, it is a ghost reading. Once your misfire goes away, the knock sensor code will disapear as well.
Twice I have gotten misfire codes and in both cases it was the coil pack. I just took mine to a mechanic, but there are ways to diagnose if a coilpack is bad. If your interested in finding out for yourself, let me know and I will scan the manual page.
BTW, if your not sure what the coilpack is, it is the part that sits on top of the sparkplug.
Old 07-16-2003, 03:22 AM
thanks lordrashmi! never really thought of coils, but if u said they cause problems i better check them anyways.
those manual pages would be helpful too if you can send them to me
thanks!
Old 07-16-2003, 07:53 AM
I am at work now, but will try to scan and post tonight.
Old 07-16-2003, 08:35 PM
Here is the Manual page. Start with the green dot. It is a pretty large image, I just wanted to get a clear picture.
http://lordrashmi.com/pics/coilpack.jpg
I believe cylinder #4 is the center, front.
Hope this helps.
Old 07-16-2003, 09:23 PM
Wow, thanks a lot. This will definately help.
Old 01-03-2004, 06:07 PM
Redcivic Redcivic is offline
Re: ECU errors, plz help (Misfire and knock sensor)
So if I have the same knock sensor code and a misfire in cylinder five it's probably the coil then right?
Http://www.Honda-Acura.net
T3+SIRII powered 93' EX
92' VX hatch new fully built D16Z6
2000 Maxima SE - rims, bolt-ons, etc.
1997 Maxima GXE - Parada's with
18" Velox VX-K's in gun metal.
Old 01-04-2004, 02:03 AM
Most likely. From what I have seen those coilpacks fail frequently.
Old 01-06-2004, 05:04 PM
MaximaSEAE01's Avatar
MaximaSEAE01 MaximaSEAE01 is offline
Send a message via AIM to MaximaSEAE01
hmm...how frequent?
SHIFT_VQ35 SWAP
Old 01-06-2004, 11:47 PM
borriss borriss is offline
Swap the suspected coil with its neighbor, reset the ECU, then wait for trouble code. If misfire occurs in the same cylinder the coil is good. Hence the prob is the plug or injector. Then do the same thing with the plug. If no change of the code, it’s an injector.
Old 01-18-2004, 06:03 PM
Thanks guys, it wa steh coil in cylinder five. It's running like a champ now.
Old 01-19-2004, 03:16 PM
hello but my car has the SES light on again. i took it to dealer on 12/30/03;after 2.5 weeks the light came on again. this time, they told me my warranty is over, and they couldn't do anything unless i pay them $120-$200. when i got my car back, i found that they turned the SES light off by resetting the ecu instead of actually fixing the problem. now i'm like wtf and was wondering if anybody would know how i can still read the error codes that was there before. in other words, is there a way how i can resurface the SES light that was there before? thanks
SHIFT_VQ35 SWAP
3300 v6 not firing right help please!!! hyorinmaru Grand AM 8 07-31-2009 03:02 PM
'99 Yukon misfires and won't start ZippyCT Yukon 10 05-29-2009 08:46 PM
Engine misfires and knocks mlupone Grand AM 6 01-04-2006 10:49 AM
installing boost controller need ecu location plz help! red12 Off-Topic 2 06-14-2004 03:30 PM
ecu question, plz help i am at the end of my rope slimmcb 3000GT/Stealth 5 02-15-2004 11:32 AM
