Old 07-15-2003, 09:04 AM
mikeshel mikeshel is offline
Unhappy O2 Sensor Check
Does anyone know if you can check an O2 sensor with a multi meter at the connector with the connector unplugged and tell whether or not the sensor is bad ? I have a 97 Olds Bravada with 4.3L.
Thanks
Old 07-15-2003, 11:05 AM
bigaldover bigaldover is offline
O2 Sensor
Hi,
The O2 Sensor carries different voltages to the ECM.
Do a search on google "GM O2 sensor"
If you have a diag tool and are getting code 44 O2 error, you may want to check you MAF Sensor, they work closely together.
Sorry I cant be of more assistance
"If you done it, it aint braggin" Roy Rogers
Old 07-16-2003, 08:35 PM
Thanks Big Al I will check that out. Actually the code I'm getting is P0507 Idle Control System HIGH RPM. I have tried almost everything just thought maybe the O2 sensors might be sneaking in the back door with out showing up as DTC's.
Old 07-16-2003, 09:30 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
There are things you can check with a meter but if you have a check engine light on it would make it easier to help knowing the code.
Things you can check;
check 5 volt reference circuit.
check ground circuit.
check the heater power circuit.
Codes 44 and all 2 digit codes do not exist anymore since 1995 model year. They are all a 4 digit code now like P0121 and so on.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Toyota Echo 2000 O2 Sensor - Check Engine light jennbk28 ECHO/Vitz/Yaris 4 12-08-2004 09:34 PM
O2 Sensor? Check Engin Light On Planck2 Camry/Camry Hybrid/Vista 5 10-21-2004 11:49 AM
o2 sensors/check engine light ibarra Thunderbird 2 02-05-2004 11:58 PM
o2 sensors/check engine light ibarra Thunderbird 0 02-04-2004 10:17 PM
MAP sensor check valves - HELP BoostedLS Forced Induction 1 03-10-2002 03:52 PM
