Old 07-14-2003, 08:17 AM
stang stang is offline
smaller supercharger pulley
Hoping you can help me!
I have a Ford Motorsport (Roots Type) supercharger on my 96 Mustang GT. The current pulley is 4" in diameter and gives 5 to 7 pounds of boost. I was wondering what size pulley I would need to buy and install to get 8 to 10 pounds of boost? Can you help me get the pulley I would need to do this and can I safety go to 10psi?
Thanks,
Jeremy
Old 07-14-2003, 12:49 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Any manufacturer who makes a pulley for that supercharger will have it listed the blower PSI it will give with that pulley
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 07-14-2003, 03:32 PM
DVS LT1 DVS LT1 is offline
I'd be very careful and do some homework - you risk detonation by jacking up the PSI.
I don't know what your engine's compression is, but I know for my type of LT1 F-Body (10.4-10.5:1) you can only run about 6-7 PSI safely without risking detonation. Anything above 8 or 9 would really require an intercooler - either that or your engine's normally aspirated compression would have to be lowered before you start feeding it big time PSI.
Old 07-14-2003, 05:36 PM
Unit 5302 Unit 5302 is offline
Send a message via AIM to Unit 5302
The 1996 Ford Mustang GT has a 9:1 CR with aluminum heads. 8-9psi should be fine on it.
Seems like the LT-1's seem to lose power early, I have always guessed the 10.5:1 CR may be part of that problem.
The Ford/SVO roots supercharger was manufactured by BBK/EATON if I remember right. At least it was back in the day.
2002 Mustang GT Coupe
1993 Yamaha FZR 600
Old 07-18-2003, 03:37 PM
The LT4 version had 10.8:1 CR and that beast made the same low, tire shredding torque of the LT1 - yet didn't lose any steam charging right up to its 6300 RPM redline.
