Old 07-13-2003, 10:43 PM
coreim30 coreim30 is offline
Question 1999 Grand Prix GT shifts funny after long drive periods
I have a 1999 Grand Prix GT which I really like a lot. I only have one problem, and it kind of bothers me. For the first hour or so of continuos driving, the car shifts just fine. After that initial hour, when I accelerate through the gears, each time the car shifts into a gear it will shudder or rumble or vibrate. Is there something wrong with the transmission? The car only has 50k miles on it. I hope you can help.
Old 07-14-2003, 09:28 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
There is a chance you have a trans problem but you could also have a ignition problem or fuel problem. Sometimes a engine miss will show up during a shift. Take it to the shop and have it check out.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 10-14-2003, 02:22 PM
mduck81 mduck81 is offline
Re: 1999 Grand Prix GT shifts funny after long drive periods
I have a 2000 grand prix gt, which I think has the same transmission. I am finally getting it fixed this week. I had three different places look at it. All three came up with the same code p1811. I am getting a valve body rebuild. My car is doing the same thing as yours. I called GM which was no help. I filed a complaint with nhtsa.gov. Gm has updated the parts for this trans since it came out. I know about four people who have had the same problem. One place said I would need a complete rebuild. After all my research I think a valve body repair is all I need. Which is gonna be about $1000.00. I hope you have better luck.
Old 10-16-2003, 07:26 PM
Flatrater's Avatar
Main GM Guy
Re: Re: 1999 Grand Prix GT shifts funny after long drive periods
From personal memory I don't think you need a valve body rebuild but you do need the PCS soleniod replaced.
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 11-10-2003, 08:49 AM
Bruce123 Bruce123 is offline
GM does have service bulletins about this problem - have your mechanic read them before doing any work. Flatrater is correct about it being an issue with the PCS. The repair also includes installing a stainless steel sleeve into the PCS piston's cylinder.
Old 11-11-2003, 12:53 AM
chort1 chort1 is offline
Someone help me
I have a 99 GT. After about an hour of city driving my trans out of nowhere will shift really hard. It seems to clunk into gear, and shake the whole car, like I ran over a speed bump. The strange thing is that I can turn the car off for a minute and start driving again and the problem goes away for another hour. Any advice? Aamco said it's probably the clutch plates and if I drive the car any longer I can burn the tranny. Another guy offered to pour stabilizer stuff into it and said the problem may go away. Will the stabilizer do more harm than good if i have to re-build it later? Thanks
Old 01-11-2004, 11:53 AM
Okie Mom Okie Mom is offline
Re: Someone help me
I also have a 99 Grand Prix and the same things are happening with the Trac Off light and the stalling. I changed the fuel filter and no change. Later took it to a dealer and they checked the computer, it said the crank went out of sync twice?? He said to keep an eye on it, but not to do anything right now. So far my car only does this about once a week.
Old 01-11-2004, 02:15 PM
pawn's Avatar
pawn pawn is offline
Banned
Send a message via AIM to pawn Send a message via MSN to pawn Send a message via Yahoo to pawn
Most likely your tranny is gettin hot. Get it looked at ASAP if not you could lose 1st gear or maybe reverse.
Old 01-11-2004, 02:16 PM
pawn's Avatar
Banned
also, how often are you checking your tranny fluid?
Old 01-13-2004, 11:39 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
I agree with pawn. If your tranny is around 50k. Replace oil, filter and pan gasket. Install a tranny oil cooler(external, cause it already has one inside the radiator). Also check your fan motor and flush radiator, since this is a city problem looks like your cooling system may starting to fail. If you solve the cooling system problem soon enough your tranny and engine will last a lot longer...
Overheating is the main cause if costly reapairs like blown gaskets, failing trannies and big stuff like this
Old 01-13-2004, 12:37 PM
pawn's Avatar
Banned
I've heard alot of people having alot of problems with the 99-01 Grand Prix Tranny. It kind of suprises me because i have no problem with mine and i run the hell out of it.
Old 01-13-2004, 02:25 PM
JJUBECK JJUBECK is offline
I bought my 99 gt with 26,000 miles on it. Now it has 78,000 miles on it and has had two rebuilds and a brand new one straight out of the crate. Yeah I'd say I've had some problems with it.
Old 01-13-2004, 03:31 PM
pawn's Avatar
Banned
How did it blow up in the first place?
Old 01-13-2004, 03:35 PM
Well the first one was from me racing it and using the the auto stick instead of just leaving it in drive. So they rebuilt it, and about two months later it started shifting rough all the time but only out of first gear. So they tore it apart again and replaced all the clutches and about a or two later it would shift out of first gear, so they replaced it with one from the factory. And it all cost me only $50.00, gotta love aftermarket warranties.
Old 01-13-2004, 03:39 PM
pawn's Avatar
Banned
How long did it take for it to go when you were doing that? I do it all the time to mine and have no problems yet. My Grand Prix has 72,000 miles on it.
99 Grand Prix acceleration problems MConder Grand Prix 7 12-11-2010 10:08 PM
1990 Grand prix le problem Erik23512 Grand Prix 1 11-05-2010 12:14 PM
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 10:20 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
1999 Grand Am nanatraci Car Audio 5 06-19-2009 07:00 PM
