Old 07-13-2003, 09:10 PM
Lecterman Lecterman is offline
Question Transmission Question
I have a 92 Accord LX Automatic and sometimes when I start my car and pull back on the shifter, it is kinda stuck in park and I have to pull on it to get it into gear. Other times it is just fine. I have seemed to nitoce that when the car is "cold" (hasn't been driven for a few hours), it tends to stick. When the car is "hot" (has been driven recently", the problem is not there. Any ideas? Do I need to change the transmission cable or something?
Report this post to a moderator | IP: Logged **
07-13-2003 07:59 PM
Profile | Send PM | Send Email | Search | Add as buddy Admin
Old 07-13-2003, 09:41 PM
94civic's Avatar
94civic 94civic is offline
happened to my friend so he changed the cable and it worked fine. he had a 91 accord lx
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 07-13-2003, 10:32 PM
BullShifter's Avatar
shift cable is binding - replace
or possible coin or soda spilled in the shift linkage
Old 07-13-2003, 10:34 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
It could also mean that you need to change your auto tranny fluid that is the only thing I could explain as to why it works when it is hot and not when it is cold. When it is cold the oil is clumping up and becoming all gummy and then when it heats up it breaks apart. When was the last time you had the Tranny fluid changed?
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
transmission question about switching 91 transmission with an 88 justgotwicked S-10 1 05-31-2005 10:29 AM
transmission questions SCMaxima2k Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 02-05-2002 09:43 AM
Transmission question Steel Engineering/ Technical 2 10-21-2001 02:56 PM
