Old 07-12-2003, 01:43 PM
saketgoyal saketgoyal is offline
Unhappy How to install CD/MP3 Player in 1999 Honda Accord LX
Hi,
I am new to this forum. I have 1999 honda accord LX. This car doesn't have CD player. I want to buy and install CD/MP3 player in my car. Is there any resource where I can find more information. This car has only Casette player and AM/FM radio. Also, there is an empty slot (I think) where I can install CD player. Basically I would like to have the capability of Casette player and Cd/MP3 player.
Any help is highly appreciated.
Saket
Old 07-12-2003, 03:21 PM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
well yes and no can it easily be done no. Not just the fact that the car only has one radio harness and it would be used on the factory tape deck you could splice off i'm not sure what affect this will have on the electrical system. the pocket underneath your radio should be large enough to hold a din size radio but there may be a little modification needed to your trim around the pocket. so in short probably yes but i'm unsure how easy it will be....
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
Old 07-12-2003, 03:59 PM
99civic03's Avatar
99civic03 99civic03 is offline
Send a message via AIM to 99civic03
Check crutchfield.com they should have what you need, including dash kits instructions etc.
Old 07-12-2003, 09:55 PM
Mrock Mrock is offline
Send a message via AIM to Mrock
To my knowledge, crutchfield doesn't have information about splicing the harness to run into two different headunits. I believe it can be done with some splicing as 60hz mentioned...but I'd assume you'd lose some power...so I'm sure it'd work, but you would only have about half the power to run the headunits. That is solemy assumption, since you'd be running two headunits off one harness. I am no audio expert, but that's my best guess...
ZC powered '91 CRX...JE 10:1 pistons, Crower rods, Bullfrog cams, Throttle body bored by Gude, Port and polished head, AEM adjustable cam gears, 340cc injectors, MSD SCI ignition, Cold air intake, clutchmaster stage 2 clutch, aluminum flywheel/heavy duty pressure plate, zex nitrous kit.
Waiting to arrive (and install, to get this baby running!)
Walbro fuel pump, PWR radiator, PM7 ECU
Look out, I can run 17's allllll day.
Old 07-13-2003, 08:32 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the power draw should not be an issue, since only one source will be providing the tunes at a time.
Old 07-13-2003, 10:18 AM
Sounds like an interesting project, then! Go for it.
Friend's mp3 Player now a melted piece of goo! RidingOnRailz Engineering/ Technical 1 03-05-2010 08:03 PM
installation of kenwood cd/mp3 players jonnie c Corolla/Matrix/Voltz 0 06-30-2005 11:04 AM
CD/MP3 Player Installation in Honda Accord 99 paaji Interior | Audio | Security 0 02-21-2005 03:00 PM
Installing Aftermarket CD/MP3 Player in 2002 Tahoe - I'm Having Problems flavarite C/K 4 08-11-2004 02:49 PM
