Old 07-11-2003, 09:41 PM
kikassboy kikassboy is offline
99 eclipse gsx buying question
i might be in the market for a 99 eclipse gsx. so i got a few questions
wat problems should i look for? i live in New jersey if regional probelms are helpful.
Old 07-11-2003, 10:36 PM
tino tino is offline
Ive heard of alot alot of 2g eclipses with crankwalk. My 97 gst has 130,000 and i havnt had it so i guess some cars dont get it.
turbos rule!!!
Old 07-11-2003, 11:30 PM
kjewer1 kjewer1 is offline
AF - Advisor
MOST cars dont get it. 99 is even less likely to get it, though they all can. Mitsu changed the thrust bearing design mid 97, or for the 98 model year. Take off the intake pipe and check for shaft play (a little bit is normal, and actually required) to make sure the turbo is ok. Try taking some tight figure 8 type turns to verify the center diff is ok. Everything is the same as buying anoy other car. Check the airfilter to verify that the previous owner took care of the car, or the dealership went through all these things. Check the oil to see how it looks. Etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-14-2003, 10:49 AM
how do i tell if the center diff is bad? wat would happen when i take tight fgiure eight turns?
Old 07-14-2003, 09:56 PM
AF - Advisor
It would bind up. You'll know it if the diff is bad It can get pretty voilent. If the diff is bad and the person kept driving it, the tranny is most likely junk too from all the metal bits floating around in the oil. Now this isnt that common, but I have seen it and thought it was worth mentioning since its AWD specific...
Kevin Jewer
How could my 95 GSX keep up with my friends' RB26DETT'ed 240's Venami Off-Topic 2 08-24-2010 08:25 AM
1998 mitsubishi eclipse rs flywheel question E. Frank Engine, Transmission and Drivetrain 4 08-22-2009 11:38 AM
WAnted to buy...97-99 eclipse GSX AWD turbo macavelli04 Off-Topic 15 01-30-2005 06:04 PM
1995 Eclipse GSX Questions ulbesry Off-Topic 5 05-28-2003 10:37 AM
