Old 07-11-2003, 06:33 PM
Dr. Doom Dr. Doom is offline
No Power
My '92 Blazer now has no power. No lights or anything will work. It won't even start. does anyone have any idea what the problem is?
Old 07-11-2003, 08:17 PM
sadlerb_98's Avatar
sadlerb_98 sadlerb_98 is offline
Send a message via Yahoo to sadlerb_98
a buddy of mine had a pontiac grand pre. same symptons. turned out to be the starter. May want to check that.
bob
Old 07-11-2003, 08:21 PM
Tercel GTS Tercel GTS is offline
Send a message via Yahoo to Tercel GTS
check the fuseable links, ask other ppl where they are on your truck, I'm assuming you checked the battery
click to chat at StonerScript
Old 07-13-2003, 08:32 AM
miratech miratech is offline
I have had this problem with both my 2000 Jimmy and 2000 Alero. In both cases, what I had was a leaking battery that looked perfectly fine until I checked it with a voltmeter. Clean/replace the battery cables and new battery fixed the problem.
Old 08-17-2003, 05:28 PM
Rob_0126 Rob_0126 is offline
Send a message via Yahoo to Rob_0126
I have a 79 el camino with a 305ho, and I had a fusible link pop one time, while I was pulling the alternator.
Nothing would work, and found out that it burned clean thru. All I did was take the burned ends, and wrap them together.
Works fine now.
Btw, the fusible link is on the starter wire cluster.
Robert
"Life is great, when you got a V8!"
Power Locks, Power Antenna, Power Loss... keyplayah71 Park Avenue 3 10-27-2009 08:54 PM
power power power badassfocus1101 Focus | C Max 6 06-07-2005 02:42 PM
Power Power Power cacattack Sonoma | S-15 5 12-04-2004 12:41 AM
no power to power windows and power seats BlueCivic83 Cherokee 0 09-10-2004 05:49 PM
Power,Power,and More power!! Did I metion Power??? BigErbGSR Engineering/ Technical 1 04-04-2002 07:44 PM
