Old 07-11-2003, 10:55 AM
EFStali's Avatar
EFStali EFStali is offline
Send a message via AIM to EFStali Send a message via Yahoo to EFStali
Using Body Filler
Alright, searched google I dont understand that shit. I have 6 small screw holes left over from my old pair of hood pins. I understand the basic part, put the body filler over it in thin layers, after that drys should i apply the hardner to it and then sand it? but if im forgeting anything please let me know.
Name is Adam
Old 07-11-2003, 11:00 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
no you mix the hardener and the putty together... and in like 10 min it'll start to dry out... and you have to make sure you sand it good and smooth, if you can feel any lines you'll see lines, and remember the more you put on the more you have to sand off...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 07-11-2003, 11:03 AM
EFStali's Avatar
okay, what grit sand paper should i use? a buddy of mine said that since its such a small area to only use 600 then 1000? does that sound right? and im guessing that ill have to remove the paint over the area thats getting sanded.
Name is Adam
Old 07-11-2003, 03:21 PM
chopstick1981 chopstick1981 is offline
if its actually a hole goin all the way through you'll want to tape the back side up first, then pre mix your filler and apply to the hole, but try and shape it right the first time so you dont have to sand it down alot, then get some 100 grit sandpaper to shape it, 200 or more grit to smooth, and then primer.
If its only screw holes you wont need to do layers of filler, 600 or 1000 grit wont help you at all if it isn't the right shape to begin with.... are you gonna paint it yourself????
Old 07-11-2003, 05:24 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
While we're on the topic, I got 5 screw holes about 1/2 inch wide from a spoiler I used to have, and you can't get to the back of it to tape it up. What should I do?
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 07-11-2003, 05:46 PM
stealthZCcivic stealthZCcivic is offline
you need to sand or grind the surounding area down, take a hammer and tap it down so it is a low spot, use some fiberglass and resin to seal the hole then do body filler, if you just fill it the outline of the hole will come back
Technical question: Body filler or spot putty? Wampa Diecast Car Modeling 7 05-05-2025 07:00 AM
Body Filler Question wondercar Camry/Camry Hybrid/Vista 2 11-21-2007 04:23 PM
Apollo bumper to body fillers wanted buickapollo455 Apollo 0 09-06-2006 08:58 PM
body filler (bondo) lckycharm713 Camaro Discussions 6 11-06-2004 01:31 PM
body fillers ModifiedCars04 Diecast Car Modeling 10 09-26-2004 01:58 AM
