Old 07-11-2003, 05:29 AM
leslieo leslieo is offline
Send a message via AIM to leslieo Send a message via Yahoo to leslieo
Question 97 accord driver door lock
I just bought a 97 accord and the driver side door wont lock from the inside. The only way to lock the door is to get out and lock it with the key from the outside. Does anybody know... is this a safety feature or is there something wrong with my door lock? I have power locks.
Old 07-11-2003, 06:17 PM
MajBach MajBach is offline
Don't know if this will help you but I'll send it anyway. it is a copy of a
letter I posted here months ago regarding a similar problem on my 97 accord.
Taking the door panels off is simple too. Just keep looking for screws,
don't forget the ones in the arm rest.
This may get to you to late, but what the hell:
I hope you get this before going to a dealer. I just finished moments
ago repairing my window/door locks.
I started by removing the door panel which is actually quite painless. After
some time using my multi meter and tracing wires, I found the problem. Right
at the front of the door [with the door open, the flat spot in the door
panel where it meets the dash when closed], there is a depression in the
door itself. This depression holds a circuit box for the door locks, a relay
for the same and two or three wiring harnesses that connect all the door
lights, windows etc before going through the door into the cabin and fuse
box. The first thing I noticed was a small pool of water in that depression.
One of the wiring harnesses is coated with felt and this absorbed the water
and eventually it seeped into the harness itself. Two of the connections
inside were so badly corroded, they were actually completely gone. I had to
remove each wire pair that had a bad contact in connect them separately
outside of the harness. Everything worked after that. thank God it was warm
today here and I found the motivation to investigate before going to Honda
on Monday and dropping $62 for a new relay; which is what I suspected the
problem was initially.
MajBach
Old 07-12-2003, 05:22 AM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
Almost all Honda's have that feature. It's so you can't lock your keys in your car. After you get used to it, it actually ends up being a really good feature.
P.S. Unless you're saying that nothing happens at all when you hit the button on the inside. It is supposed to lock but after opening the door, and shutting, it unlocks itself.
Old 07-22-2003, 08:41 AM
imfastidious imfastidious is offline
when inside--use the lock switch
when leaving--the key or hold up handle & push down lock
Old 07-22-2003, 09:58 AM
darkaccord darkaccord is offline
Send a message via AIM to darkaccord
When the door is open, lift the handle on the outside, and push the door lock on the inside at the same time. It will lock all the doors.
2002 Buick Regal remote control door lock receiver brytheisen Regal 2 07-20-2010 12:07 PM
04 yukon xl driver door instrument panel problems kminton85 Yukon 0 01-09-2010 11:57 PM
Drivers door/ lock, elec. mirrors, int. lights, door ajar light JamesD Explorer | Explorer Sport Trac 5 04-08-2005 10:42 AM
91 4 door Accord SE door locks ?????? Huffa Accord/TSX/Accord Hybrid 8 10-22-2004 08:14 PM
97 accord driver door lock leslieo Car Audio 4 07-11-2003 06:41 PM
