Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 11-17-2001, 12:03 AM
93InfG20 93InfG20 is offline
Engine Noise
Anyone had a problem with engine noise coming through your speakers when using an amp and subs? Anyone know how to fix it?
1993.5 Infiniti G20 5-speed Silver
JDM SR20DE
OBX Muffler
JWT POP Charger
5" LCD Screen
Old 11-17-2001, 12:25 AM
frogg's Avatar
frogg frogg is offline
Send a message via AIM to frogg
The reason you're getting engine noise could be because of your grounding. Try regrounding your head unit and amps or grounding them to a different spot. Make sure where you are grounding them is connected directly to the chassis. Also, for better results, scrape the paint off (if any) around where you are grounding.
There are also, I believe, things called "ground loop isolators" that will get rid of engine noise. That's about all I know though.
Old 11-17-2001, 12:27 AM
Any other suggestions? I've tried all mentioned above
JDM SR20DE
OBX Muffler
JWT POP Charger
5" LCD Screen
Old 11-17-2001, 12:59 AM
frogg's Avatar
And you've ran your speaker wires away from any power wires?
Old 11-17-2001, 01:08 AM
yes I have
JDM SR20DE
OBX Muffler
JWT POP Charger
5" LCD Screen
Old 11-17-2001, 01:15 AM
frogg's Avatar
Hmm.. do you have any of your wires ran near anything like, for example, spark plug wires in your engine compartment?
Old 11-17-2001, 01:32 AM
no my wires are run as far away from everything as they can get
JDM SR20DE
OBX Muffler
JWT POP Charger
5" LCD Screen
Old 11-17-2001, 01:39 AM
frogg's Avatar
I'm trying to think of something else. Only thing I know that will most likely work would be putting ground loop isolators in. Gimme some time.. I'll come up w/ something.
Old 11-17-2001, 05:33 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Alternator going?
-Brian Jones
I got a snake man
Old 11-17-2001, 05:51 PM
Alternator going? Im getting alternator whine comeing from the engine
JDM SR20DE
OBX Muffler
JWT POP Charger
5" LCD Screen
Old 11-17-2001, 06:31 PM
frogg's Avatar
I think he means, is your alternator crapping out on you
Also, tell me exactly where your head unit and your amp(s) are mounted
Old 11-17-2001, 11:25 PM
The head unit is mounted in the normal DIN opening. The amp is mounted on top of my speaker box.
JDM SR20DE
OBX Muffler
JWT POP Charger
5" LCD Screen
Old 11-18-2001, 12:31 PM
frogg's Avatar
whoops meant grounded, not mounted
Old 11-18-2001, 10:23 PM
head unit is grounded with the factory ground wire
amp is grounded to bare sanded metal in the trunce
JDM SR20DE
OBX Muffler
JWT POP Charger
5" LCD Screen
Old 11-18-2001, 10:36 PM
frogg's Avatar
Ok, I'm 99% sure it's your head unit grounding. Ground it to something other than the factory ground. Grounding it to the factory ground is what causes 90% of engine noise in sound systems.
2005 Escape LTD - Engine Noise charettk Escape | Maverick | Escape Hybrid 8 11-05-2010 09:24 AM
'81 Deville 368 engine noise 83mb380sl Deville 2 10-17-2010 06:09 PM
1996 Avalon XLS Engine Noise Sarma Avalon/Pronard 0 06-22-2010 09:03 PM
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 06:25 PM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 06:23 PM
