Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-07-2003, 09:30 PM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
Cat Back ?
Well, I finally found someone in this town to make me a custom exhaust, but I have a question...I was told that the cheapest way to do this is to buy a Bomb Muffler on Ebay and have the pipe bender put that on. But when looking for the muffler, they all say they have a 2.5" inlet. I thought Integra's were supposed to have 2.25" pipe. Is this going to be a problem for the guy? Or is this just how it goes? If this kind of muffler isn't going to fit, what kind do you guys suggest?
Old 07-07-2003, 09:35 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
I got a vibrant muffler and I have to say it is one of the best sounding mufflers I have ever heard, it sounds alot like the RSR exhaust and it is a straight thru style, but it is not loud at all just in the upper rpm range but even then you can still hear the intake over it. That is how you know if your exhaust is too loud( you cannot hear the intake over the exhaust, except ppll with cai they sound alot quieter inside then a short ram) IMO.
Old 07-07-2003, 10:06 PM
loesch8102's Avatar
How much do you think I can get one for? Where?
Sorry, nevermind. I was just being lazy. I found one on eBay. If anyone else has a comment, I'd still like to hear it. I'm still lost on the whole 2.5" 2.25" thing. Thanks!
Old 07-08-2003, 02:59 AM
loesch8102's Avatar
I'm sorry for bumping up this topic, but I am kind of in a hurry. The auction ends in like 17 hours and I want to make sure I don't screw myself. Will an auto shop have problems mating a muffler with a 2.5" inlet to the 2.25" pipe that is supposed to be from the cat to the muffler? And it is suposed to be 2.25" for an Integra LS right? Please excuse me if this is a stupid question.
Also, how restrictive is the stock exhaust? Will this really give me any noticable gains without aftermarket headers or high flow cat?
Old 07-22-2003, 09:36 AM
99' Z-28's Avatar
99' Z-28 99' Z-28 is offline
No, the muffler shop will make a pipe that will fit over both. Most muffler shops have pipe benders and pipe expanders. I wouldn't worry or lose sleep over the 2.25 to 2.5inch thing.....
Yes, but don't worry about the size, 1/4 of an inch is not a big deal.
When you have a stock cat, stock resonator, and stock muffler....its gets quite restrictive. I doubt your stock muffler flows more than 260cfm (cubic feet per minute). A performance muffler will give a noticable gain, even if you don't have aftermarket headers or cat.
AF User Guidelines
-Exhaust Man
-Race Car Driver
Old 07-23-2003, 01:29 AM
acuraattack92 acuraattack92 is offline
If you help the car breathe better through both ends; intake and exhaust then youcan see a difference in your 1/4 mile times and better performance on the upper end of the power band. I would suggest tightening valve lash as well to get a bigger cam effect. The you will see the gains
Old 07-23-2003, 05:05 AM
loesch8102's Avatar
What exactly is that and how do I do it?
Old 07-23-2003, 07:54 AM
Kilboy57 Kilboy57 is offline
I'm curious to know what valve lash is also...
Life is a lesson; you learn it when your through
Old 07-23-2003, 10:40 AM
99' Z-28's Avatar
Valve Lash is the clearance (space) between the bottom of the valve stem and the top of the lifter stem. If you do not adjust the valve lash, your valves will not close completely when the engine reaches operating temperature due to the expansion of metals. Removing material from either the valve stem or the lifter stem to create this clearance.
This would have been a good topic to bring up in Engineering/Technical.
AF User Guidelines
-Exhaust Man
-Race Car Driver
Old 07-23-2003, 02:51 PM
I'll bring this up in a forum...cuz I'm still a little foggy...ur last sentence, 99 Z28, do u mean its good or bad to remove materials from the valve???
Old 07-23-2003, 03:05 PM
loesch8102's Avatar
So basically, just get your valves adjusted every 15,000 miles?
Old 07-23-2003, 04:29 PM
whtteg's Avatar
That is the worst thing i have ever heard! Don't do that it will screw up your cams, rocker arms , and valves! Keep the valve lash within spec and nothing else.
Kilboy57: No it is not good to remove metal from the valves or rocker arms, this is just what happens when you have the valve lash too tight.
loesch8102: every 30,000 miles is the norm.
Old 07-23-2003, 09:52 PM
99' Z-28's Avatar
Well, you know, it depends. You need to remove materials to get the valves to close completely and create clearance. There is a special tool to check this with.
AF User Guidelines
-Exhaust Man
-Race Car Driver
Old 07-23-2003, 10:12 PM
You should keep the lash adjusted close to with in the factory specs. Adjustment too tight will screw everything up and could even have piston and valve clearance problems. However there are tool to do the job right. I didn't mean that you should remove material either. I was just refering to adjusting through tightening the screw above each valve until they are snug. Every integra that I have had has needed this adjustment because it is often overlooked. Keep the lash snug and not too tight.
Old 07-24-2003, 03:05 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
vibrant exhaust
Whtteg I was lookin at different vibrant exhausts and was wondering which one you have? what you described is exactly what i am looking for in an exhaust so if you know which one it is that would be great.
Stainless Steel Cat-back or axle back?? klohiq Integra 1 01-26-2010 12:04 AM
axle back VS. cat back rpsthirteen 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 04-10-2004 08:59 PM
Apex N1 Cat-back and a Bonez SuperFlo Cat - FOR SALE 02MaxSE RX-7 0 04-09-2002 12:21 PM
Custom 2 1/4" cat-back installed!!! Woohoo! NismoPC Engine 0 09-08-2001 07:59 AM
P11 Greddy Cat-back b-b00gie Engine 10 08-17-2001 12:59 AM
