Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-07-2003, 07:18 PM
tano tano is offline
Dragging Integra Gsr
Hi,
I just got a 2001 integra gsr ( completely stock ) and i took it to the track last week and my best quarter mile time was only 15.9 @ 89mph. From doing reasearch on the internet , my car should do it in 15.6.
I cant understand the problem ( and yes I consider myself a good driver). I drop the clutch at the start at 4500rpm and i shift at about 8100 rpm.
Can Anyone help me!, the only thing i can think of is that i should feel out the clutch rather than popping it. Also i have 35000miles on the car and i havent changed the spark plugs yet, since i heard that integras come with 70000mile spark plugs, can this be the problem, does anyone have any tips on how i should launch the car and can STOCK gsr owners give me thier times.
Thanks.
Old 07-07-2003, 09:28 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
You will prob never get it down much lower launching at 4500 rpm, but I dunno try to feather the clutch and keep the car in vtec, ie: let the clutch slip a little to keep the rpm in the 4500+ range while launching, I have headr that this works well but i don't know b/c I have no vtec
Old 07-08-2003, 09:24 PM
Options Options is offline
Send a message via AIM to Options
Im not a GSR owner my-self, but my best friend has a stock GSR except he put on an Injen CAI a few days ago, or i put it on for him lol. Ne way you should be running far faster, then high 15's his best run when his car was completely stock was a 14.9. If you could post the stats of your time slip like your 60ft, 1/8 mile, and reatction time we could see where you could improve on. It could also be where you ran your car at wheather has a lot to to with how cars run, luckly for where we run our cars, the track's elevation is 0 meaning it is at sea level so the cars here run faster then the cars at higher altitudes, because the higher you go the thiner the air gets making it harder for the car to breath. I my self have ran a 16.4 in my DX at that track. Ne way post your slip, and keep practicing.
Its not how fast you go it how fast you finish.
Second place is the first looser
Skunk2 Coil-overs
Aem 2 piece intake
Tanabe Exausht
Throttle Body coolant bypass
Apexi SAFC 2.
Skunk 2 cam gear.
ZEX dry nitrous system: currently 55 shot.
Best 1/4 Time:
16.402 @ 82 M.P.H w/ 2.290 60ft w/o spray 14.8@94 MPH w/ spray
Old 07-21-2003, 01:15 AM
99GSR's Avatar
99GSR 99GSR is offline
When my gsr was stock i used to run 15.7-15.9 its impossible to run 14.9 on a stock gsr the best time you'll get on a stock gsr is probably 15.6
Old 07-21-2003, 04:15 AM
Dude, Civic Si's run 15.6 stock. If what your saying is true i should be running mid 17's with my car, which isnt the case. I run 16.410 in my Dx with 106 h.p. and like 90 ft/lbs of torque, your car has 170h.p. and 127 ft/lbs of torque. Just get used to your car more and youll do better.
P.S. a local shop around here ran a completely stock GSR before they turbo'd it and they ran a 14.7 with full interior and everything. go to www.groundzeromotorsports.com i think there still hosting the video of there run.
Skunk2 Coil-overs
Aem 2 piece intake
Tanabe Exausht
Apexi SAFC 2.
Skunk 2 cam gear.
Best 1/4 Time:
Old 07-22-2003, 01:53 AM
york2600 york2600 is offline
Send a message via AIM to york2600
Just a few suggestions here
1) How much tred is one your tires, are they good tires and did you have the right PSI in the tires
2) Get a tuneup it does wonders and you'll get better MPG when it's done
3) Practice your launch.
4) Different tracks =s different times
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
Drag Integra ElRxBandito Diecast Car Modeling 11 05-17-2006 02:53 PM
integra gsr or integra type R???? teg#1 Integra 24 03-04-2004 09:28 PM
Drag Integra Wes Moran Car Modeling 10 07-09-2002 07:18 AM
Apexi Drag Integra vs. AEM Drag Civic Turbo99Eclipse Car Comparisons 1 12-27-2001 01:01 AM
Integra GSR vs. 'Stang GT enzo@af Car Comparisons 13 09-08-2001 06:30 PM
