Old 07-07-2003, 03:11 PM
shohoku81 shohoku81 is offline
Cool will installing front strut bar make tire worn out less?
I have civic hx 99.. and was wondering if strut bar will make tire worn out less.... and if it will save gas too?
What's good about installing strut bar?
Old 07-07-2003, 03:25 PM
csaddict's Avatar
csaddict csaddict is offline
An upper strut bar will not affect tire wear. It will not affect gas mileage either. It will stiffen up the upper strut mounts from lateral flex.
[size=1/2]96 Civic CX Hatch
1.6 Non VTEC
Full length CAI
Custom Catback Exhaust
Short throw
H&R stage II springs
Tokico Illumina adjustables
front upper,rear upper,rear lower tie bars
ST front and rear sway bars
BOOSTED![/size]
Old 07-07-2003, 03:44 PM
99civic03's Avatar
99civic03 99civic03 is offline
Send a message via AIM to 99civic03
Yeah it really just improves handling thats about it.
Old 07-08-2003, 05:56 PM
Options Options is offline
Send a message via AIM to Options
Yep, if ne thing it will worsen tire wear because its reducing body roll, and reducing the weight thats put on the outside tire while cornering, causing the car to understeer (hence makes the car not want to turn), because there is no weight on the tire so it kinda slides accross the ground in away.
Some one correct me if im wrong.
Its not how fast you go it how fast you finish.
Second place is the first looser
Skunk2 Coil-overs
Aem 2 piece intake
Tanabe Exausht
Throttle Body coolant bypass
Apexi SAFC 2.
Skunk 2 cam gear.
ZEX dry nitrous system: currently 55 shot.
Best 1/4 Time:
16.402 @ 82 M.P.H w/ 2.290 60ft w/o spray 14.8@94 MPH w/ spray
Old 07-09-2003, 01:13 PM
emerge's Avatar
emerge emerge is offline
Send a message via AIM to emerge Send a message via Yahoo to emerge
well you're not wrong, but you are kind of over-exaggerating. strut bars only really become effective once you take sharp turns at 60+mph, which is just
1. stupid
2. going to wear your tires out anyways.
as far as day-to-day driving, i don't think a strut bar will wear out tires any noticeable amount. good point though
p.s. my first point about turning at high speeds ("1. stupid") does not concern autocrossing...
Stephen Gladney
Original PH Member
EJ8 Civic | AIM: nxzo | www.rtek.org
Old 07-09-2003, 02:14 PM
Gotta agree with you emerge.
Skunk2 Coil-overs
Aem 2 piece intake
Tanabe Exausht
Apexi SAFC 2.
Skunk 2 cam gear.
Best 1/4 Time:
Stillen Front Strut Bar and Rear Sway Bar For Sale! redhurley Classifieds 1 02-27-2006 10:56 PM
installing front strut bar. RADMANX Off-Topic 2 12-10-2004 06:45 PM
Installing front strut bar. 03DMeclipse Eclipse 2000+ 4 07-23-2004 10:33 AM
installing upper strut bar on 04 corolla s tracek180 Corolla/Matrix/Voltz 1 07-22-2004 12:40 AM
Will a Civic strut bar fit on an Integra? Ricochet Integra 2 08-01-2003 07:59 PM
