Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 04-02-2024, 06:49 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Lost ABS
I replaced the Brake master cylinder some time back and one morning the brake pedal went to the floor. The brake line going to the front wheels wasn't tight enough and leaked out fluid so I tightened it, refilled the reservoir, bled air off and everything was OK except the ABS light is On and I have no ABS..
Any ideas?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 04-02-2024, 07:18 PM
maxwedge maxwedge is offline
A990 racer
Re: Lost ABS
Chris, sounds like air trapped in the abs unit. Check the bleeding method, newer units need a scanner to do this.
Old 04-25-2024, 06:08 PM
AF - Advisor
Re: Lost ABS
The FSM keeps referring to the Tech 1 Scan Tool....guess I need to be on the lookout for one before they're gone.
Old 04-26-2024, 09:53 AM
Blue Bowtie's Avatar
Registered Offender
Re: Lost ABS
Keep in mind that a Snap On MT2500 with the appropriate modules can do the same thing, which may expand the options a bit. That was valid at least up to 2002 for most models, and later on some.
The Following User Says Thank You to Blue Bowtie For This Useful Post:
Chris Stewart (05-07-2024)
