Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 07-06-2003, 12:45 PM
PowerCrazy PowerCrazy is offline
new tib engine?
i've heard that there is a rare GT model that comes with a 3.5L instead of a 2.7L, i can't remember where i read it but i was wondering if any of you had heard anything about it and availability and how much extra it would be. it would be kick ass though because they're already fast with the 2.7L pulling 170hp..... imagine a 3.5L pullin probably around 230hp. Now you're talkin closer to the new 350Z almost, they run a 3.5L with right around 300hp (i think).
Old 07-06-2003, 03:30 PM
dolla_bill0913's Avatar
dolla_bill0913 dolla_bill0913 is offline
Someone probly took the XG350 3.5 DOHC 24V V6 and put it in a tiburon. The tranny of the tiburon is the same as the Santa Fe, due to this fact I already have seen a twin turbo all wheel drive tiburon. This is a car that you can make lots of aftermarket changes, the only downside is you void that nice long 10 year warranty if you do anything too extreme. This is the tiburon that was at the New York auto show this year. http://www.hyundaiusa.com/customs/im...ronMIbig_1.jpg Modified by:
Modern Image
Modifications Include:
• Custom PPG Yellow Paint by Car Prep
• Custom Four Seasons Body Kit by
Shark Racing
• Candy Coated Front and Rear Lights by Wet Works Garage
• Custom Mesh Grilles by Wet Works Garage
• Intrax Lowering Springs
• Wildwood Big Brake Kit Including:
Front 13" Rotors and Six Piston Calipers
Rear 13" Rotor and Four Piston Calipers
• Magnaflow Performance Exhaust System
• 19" - 8" Modern Image Stance Wheels
• 215/35/19 Yokohama Tires Parade Spec 2
• Fluidyne Aluminum Radiator
• Custom Turbo System Fabricated by Road Race Engineering Featuring Turbonetics Turbo, Waste Gate, Blow -Off Value, Spearco Intercooler
• Thermal Flex Hoses
• Nitrous Express Nitrous System
• Candy Blue Powder Coating by Specialize Powder Coating
• Polished Manifold and Parts by California Polishing
• Sparco, Seats, Steering Wheel, Shift Knob, Pedal Kit, Harness
• Custom Painted Trim Panels
• Roll Cage by Twisted Tin
• Custom Aluminum Floor by Twisted Tin
• Custom Interior Upholstery by Stichcraft Custom Interiors, Door Panels , Head Liner, Arm Rest etc.
• Custom Stereo System Featuring, Clarion Audio Video Head Unit DVD Player CD Changer, Cutting Edge Audio Amps and Speakers
Old 07-06-2003, 03:42 PM
i don't know how much you know about hyundai but i'll ask.... a.) what about dropping the santa fe 3.5L in a tib, the santa fe runs better specs than the XG350.. and b.) do you know if it's possible to bore out and change the stroke on even the 2.7L tib GT V6? because im lookin to turn mine into one hell of a car, my aim is to be able to compete with high performance sports cars.
Old 07-06-2003, 04:02 PM
As far as switching engines and boring out / changing the stroke of the 2.7, yes I am sure both could be done with lots of time and money, but there are a lot cheaper and easier ways to make a tib faster. Nos is always the cheapest way, and if you need your car to get around day to day, I would start with smaller engine mods first (intake, exhaust, turbo, intercoolier,etc.).
Old 07-06-2003, 04:08 PM
i've already got all that lined up and am projecting around 400hp, maybe higher.... 550hp with a shot of nitrous..... but to get it there will be rather exspensive, with the turbo (or possibly twin turbo if it comes out soon) i was just wondering if there was a way to start off with more then the 170hp and 181lbs/in that the 2.7L is stock. I know i can already beat most ricers stock and almost all with a few mods, but like i said, i want to run with the big boys.
Old 07-06-2003, 04:18 PM
The 2 things you dont want to forget is first no matter how much crank power you are putting out you still have to get it to the ground, and second (most important if you change the engine) the aftermarket parts have to fit the engine, so if you get a new engine you will need to find parts that will fit that engine (thats why most people just mod the stock engine).
Old 07-08-2003, 02:51 AM
Er0 Er0 is offline
Send a message via AIM to Er0 Send a message via Yahoo to Er0
I would check around from what i hear your car has problems around the 250hp range
this is what i have heard on other forums
Old 09-13-2003, 11:38 PM
Black2k3Tib Black2k3Tib is offline
240HP Limit
So far what I have found out about the 250HP Limit on our 2.7 blocks is that they are 4 bolt mains. The particular material that the engine is made of expands too much around 240HP and the point where the bottom end holds the 8 bolts in place will actually lose hold of the bolts and lose the crank. So far that is what I have found always being nosey though. Sure I will find out more.
Robert
Be waiting for you at the finish line...
I want a new Tib! DLD84 Tiburon | Tuscani 6 07-07-2005 12:23 AM
new tib sports car....more than u ever thought possible KTiB Tiburon | Tuscani 23 05-02-2005 03:31 AM
I wanna keep my new Tib nice inside too leadfoot411 Tiburon | Tuscani 9 10-31-2004 04:52 AM
new tib and 5k to spend first2belast Tiburon | Tuscani 4 07-30-2004 11:15 AM
New Tib owner - Needs advice henrod Tiburon | Tuscani 11 07-22-2004 09:41 PM
